Normal readings?
Old Sep 8, 2015 | 04:22 PM
bizzelj's Avatar
bizzelj
Normal readings?
Snapped this at idle on the way home. Everything look ok to you guys?
Old Sep 8, 2015 | 04:26 PM
WatsonR's Avatar
WatsonR
The ICP DUTY cycle is IPR and if that's right, 25% is kind of high and may indicated an internal leak. What is your cranking like at cold and warm starting?
Old Sep 8, 2015 | 04:30 PM
bizzelj's Avatar
bizzelj
Cranking times are good. 2 to 3 seconds warm or cold. It usually reads around 23 but today for some reason it hit 25 at idle
Old Sep 8, 2015 | 04:39 PM
WatsonR's Avatar
WatsonR
Keep and eye on it. When was the last oil change? Mine runs 21-22 and nearer to 23 when the oils getting old. Changed oil yesterday, solid 21.1 again.
Everything else looks pretty good. Battery voltage is near the bottom acceptable, unless your running everything in the truck. Mine runs 13.7-14.2 even with everything on. Check it with a meter, should probably read about .5 higher that way.
Old Sep 8, 2015 | 04:45 PM
69cj's Avatar
69cj
Your engine isn't completely warmed up. Oil is usually a little warmer than ect.
Old Sep 8, 2015 | 04:50 PM
bizzelj's Avatar
bizzelj
Oil change was about a thousand miles ago just drove it around for about ten minutes and i got 22 23 at idle
Old Sep 8, 2015 | 04:51 PM
bizzelj's Avatar
bizzelj
What kind of internal leak are you talking about?
Old Sep 8, 2015 | 06:53 PM
KDAVID1's Avatar
KDAVID1
Normal readings?
Hpo system leak
Old Sep 8, 2015 | 07:30 PM
bizzelj's Avatar
bizzelj
Originally Posted by KDAVID1
Hpo system leak
I did the stc upgrade a few months back can they fail that quickly?
Old Sep 8, 2015 | 07:34 PM
KDAVID1's Avatar
KDAVID1
What year engine?
If later model could be stand pipes or dummy plug.
Could be injector cup orings, or hpop. Just need an air test to pinpoint if and where the leak is.
Old Sep 8, 2015 | 07:35 PM
WatsonR's Avatar
WatsonR
No, but you have dummy plugs and standpipe and injector o-rings that can leak... small leak. Why it's at 25% and should be about 21-22 or so. I've heard of 23-24 as normal also, just think 25 is a little high. You could have a screen in the IPR with some stuff on it as well.
Old Sep 8, 2015 | 07:41 PM
bizzelj's Avatar
bizzelj
Stand pipes and dummy plugs were replaced as well I mean it was the first time I seen it. Going to monitor for a few more days I guess and I also run a performance tune on it if that means anything
Old Sep 8, 2015 | 08:04 PM
WatsonR's Avatar
WatsonR
I run SLR+ and Atlas 40 as well. Keep an eye on it and see if it shows again. Check the screen of the IPR, you could have made a catch.
Old Sep 8, 2015 | 08:09 PM
bizzelj's Avatar
bizzelj
Is there a video or instructions on how to do that I am no mechanic I can do basic things but the most I've done on the truck so far is change the alternator
Old Sep 8, 2015 | 08:22 PM
WatsonR's Avatar
WatsonR
Takes an IPR socket and an extension. Google a video I'm sure there one out there.
