TPMS ON A DUALLY
Old Sep 10, 2015 | 11:28 AM
paulkaa's Avatar
paulkaa
Got it.
I want to add a TPMS on my travel trailer. What are the pros and cons? What experiences have people had? Thanks for any response.
Paul
Old Sep 10, 2015 | 11:31 AM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Originally Posted by paulkaa
Don't these trucks come with a factory TPMS? What am I missing here?
Originally Posted by sdetweil
Not duallys
...and the aftermarket systems are far superior to Ford's minimal system.
Old Sep 10, 2015 | 11:44 AM
sdetweil's Avatar
sdetweil
Got it.
Paul
We almost all use Truck Systems Technology (TST) 507 sensor systems
I have 6 on my truck and 4 on my 5th, (and 4 on my car hauler, cause I don't want to move them and reprogram the controller all the time)
Old Sep 10, 2015 | 01:24 PM
Just Strokin's Avatar
Just Strokin
I prefer the TireMinder style of screw on pressure units. When i need to add air, it verifies to me that the sensor is working properly as it gives an error indication till i screw it back on.
The newer Tirminder systems allows you to separate the truck and trailer tire sensors so you don't get erroneous sensor failures when you are not pulling the trailer.
I run a sensor on all tires, including the spare. Cost is a little higher initially but to me is worth it in the long run.
Old Sep 10, 2015 | 01:26 PM
Just Strokin
Nice Larry..
put the inner extension on, then the outer wheel? I couldn't get my hand back to the inner at all.
no out of balance problems with all that weight in one place?
I added balance beads to my dually tires to help avoid that.
The extension is screwed on and alligned with a few trial fits of the other wheel.
No, the there is no out of balance noticed with the addition of extension and two pressure senders.
Old Sep 10, 2015 | 02:03 PM
sdetweil's Avatar
sdetweil
I have a Tire Tracker (same thing as minder) system sitting here, 4 tire, and the TST screw on sensors are fundamentally the same.
I have flow thrus on the trailers, but cap style on the truck.
TST also allows u to turn off/on the trailer tires.. one reason I picked them. also the sensors respond much faster than my tracker. I had a tire blow on my trailer (with my custom truck inside) 12 miles from home, but the sensor didn't wake up until I put the spare on!..
TST's are alive before I get out the driveway. the monitors are similar.
Krisx125
815
Apr 8, 2026 10:09 AM
Paw's 150 Lariat
Oct 24, 2020 11:28 AM
lindenj
Oct 24, 2020 02:40 AM
ChunderDownUnder
19
Aug 1, 2009 09:17 AM
Storm
Oct 4, 2007 12:59 PM
