what is this
Old Sep 7, 2015 | 09:26 AM
Hardlanding's Avatar
Hardlanding
what is this
I broke this one, there are two side by side on my 93 f-superduty with the 460, I think this is adding to my slew of problems from a botched engine swap someone did...thanks in advance
Old Sep 7, 2015 | 10:05 AM
'89F2urd's Avatar
'89F2urd
that is a valve for the air pump system. it doesn't effect anything as far as drivability, unless you have a vac line broken causing a leak issue.
Old Sep 8, 2015 | 08:26 AM
Hardlanding
It is not broke on the vacuum side it is blow air out of it...I am going to try and replace because when I seal it up it helps with idle a little... I need to find a vacuum and plumbing diagram for this thing
Old Sep 8, 2015 | 09:10 AM
'89F2urd's Avatar
'89F2urd
You could just delete the system entirely. If you go that route, just leave the solenoid hooked up (follow the vac line to solenoid)
RVF150
19
Jan 12, 2021 09:27 PM
TheGreat460
May 11, 2020 03:25 PM
WhatsAChevy?
May 16, 2016 09:24 AM
crackahcrackah
Feb 18, 2012 01:53 AM
Gunner33
May 11, 2009 07:08 AM
