fuel leak
Old Sep 6, 2015 | 01:56 PM
frizzen's Avatar
frizzen
fuel leak
I have a very slow fuel drip off the housing for the fuel filter on the engine. can't see where it's coming from . It started sometime after I changed the filter a couple of months ago.
Any one had a similar experience or ideas?
Old Sep 6, 2015 | 02:17 PM
evan1242's Avatar
evan1242
go ahead and get a new filter so you get the new o ring. (it is probably ripped)
while you have the filter out, check the old o ring for rips or tears. also check the cap closely as they can crack too. also don't use a ratchet on the cap. use a socket.
when you put on the new o ring on make sure it is in the right slot in the cap, and cover it with some fresh motor oil to lube it up so it doesn't rip again when you tighten it.
turn the key on for 4-5 full fuel pump cycles (listen for the pump to turn off)
then start her up and re check for leaks.
if you still have a leak after that, it may be leaking from the regulator side.
if your going to crack that open, you should go ahead and get the blue spring kit from ford.
that way, you will have all the gaskets you might need while you are in there and also you will know for sure that you have a blue spring.
it will also come with a new cover in case that breaks.
before starting on that use a turkey baster to remove all the fuel from the bowl so it doesn't go every where.
Old Sep 6, 2015 | 02:20 PM
lupuseven's Avatar
lupuseven
Use a sharpee and make a line below the cap then around each fitting. come back and look for break in the line. this will help you at least get closer to where it might be.
Or just disconnect , reconnect all fittings and cap.
Old Sep 6, 2015 | 03:18 PM
KDAVID1's Avatar
KDAVID1
fuel leak
Mine was the regulator housing gasket.
Put the blue soring in and new gaskets. Was good to go.
Old Sep 6, 2015 | 03:54 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
With the engine running, run your finger around the fuel filter housing right at the cover/housing interface. If it gets wet, then it's your cover o'ring. If you don't detect any wetness, then run your finger under the regulator housing. If it gets wet, then it's you regulator housing o'ring (pretty common). Get the blue spring kit if you haven't done the upgrade as it comes with everything you'll need.
Old Sep 6, 2015 | 04:59 PM
frizzen's Avatar
frizzen
Thanks to all
7.3 Powerstroke Guy
28
Dec 24, 2018 03:35 PM
staarma
Apr 28, 2015 07:52 PM
bakerbuilttracks
Nov 20, 2012 10:05 PM
renoduckman
May 5, 2012 08:39 PM
Jenners
Apr 22, 2005 01:40 AM
