Recently had a brake job done on my 66f250 (previous Ride Of the Week), The truck is pulling hard to the right, I've had it back in the shop for the 3rd time, and now they are telling me they don't know what's causing it.. (a good shop)..
here is a list of what was done..
All drums resurfaced, and shoes replaced
replaced flexible hoses, and cylinders
bled the lines..
worked ok for awhile (about a month), and then started pulling right.. the shop has adjusted and adjusted, it just keeps coming back.. My thought is that one of the slave cylinders is not working properly,, but no leaking present...
appreciate any ideas and or thoughts about what might be causing this.. Thanks in advance
Is the right front brake getting hot when it starts pulling?
When it binds down, does it "release itself" after sitting over night?
If it was mine, I'd suspect that the right front flex line (although new) is failing anyway. I would replace that flex line and then re-bleed the system.
Was it having this problem before the brake job? If so, I would try replacing the hard lines to the right side. If not, then I second the right flex lines and the right wheel cylinders.
thank you for the reply, It does not lock up, it just feels as if the adjustment is wrong, and when stepping on the brake it pulls to the right, then when released it returns to normal..
I thought the same thing about the wheel cylinder that even though it's new , it could be defective.. but did not consider the flex line..
It was not acting like this prior to the break job,, I actually took it in to to have the wheel bearing replaced, and the shop spotted the leaking cylinders.. at that time it was not pulling..
I will pass on your reply to the shop,, you feel that the flex line should be replaced, and possibly the cylinder also..
thank you
So long as we're WAG, considering the hoses have been replaced it seems to me the more likely culprit at this point would be a partial obstruction in the hard line? Also consider if it's pulling to the right, the problem may be in the left side of the brake system. Can also be a M/C problem.
Now that he described the problem a little further, it does sound like the left side could be the problem too. Either the right side is braking too much, or the left is not braking enough. The fact that it does not lock up/goes away when you release the pedal sounds a little more like it could be the left not braking enough. Don't rule out the back wheels either.
Get a helper, put the truck on jack stands, spin the wheels one at a time, and have your helper step on the brakes. Do all the wheels stop when the pedal is depressed? Does any wheel have less resistance while the pedal is depressed? Do they all spin freely again when the pedal is let go? This could help you locate the problem.
An obstruction in the line usually causes brakes to lock up. The pressure flowing toward the wheels when you apply the brakes is higher than the pressure flowing back when you let go. So, fluid gets in but can't get back out. Air in the line usually causes one or more wheels not to brake as hard or not at all. Instead of the fluid flowing to the wheel cylinders, the air gets compressed.
I don't know if the MC is the stock single reservoir version or, if the truck has been converted to a tandem, dual reservoir MC (?).
In either case, if any of the brakes are working --especially to one of the front brakes, the problem would have to be after the MC. The fluid pressure being supplied by the MC to the front and rear brakes would be equal throughout the entire brake system (Pascal's Law).
A restriction in the lines or a sticky or malfunctioning wheel cylinder could cause the fluid pressure not to actuate the brakes as it should but, the pressure in the brake lines up to that trouble point would be the same as what's being applied to the rest of the brake system.
If the MC is actuating any of the brakes, the problem is down stream from there.
Pascal's Law states that the "Pressure applied to any part of a confined fluid transmits to every other part with no loss. The pressure acts with equal force on all equal areas of the confining walls and perpendicular to the walls. This is the basic principle for any hydraulic system."
I had a similar problem - turned out the new brake shoes I installed on the front end would seep out whatever material they were made out of, or perhaps were just defective. It took the shop several tear downs and brake line replacements to figure that one out. I pulled my hair out by then.
Wow, thanks for all of the replies.. I will pass all of this on to the shop.. a couple notes.... The front end is tight, no problem there ,, and the MC is original, (i mean stock), no problem there either..
is there any way to check for a possible obstruction in a line??
will keep you informed as to the eventual fix.. (i hope)..
thanks again..
Remove the bleeder from the wheel cylinder, install a brake pressure gauge, step on pedal, take gauge reading. Move to next wheel, repeat process, compare pressure readings.
The P/O did a brake job on the rear of my F100. He got the adjusters installed on the opposite sides. The one on the left side was trying to tighten the shoes up but was actually making them loosed, reverse on the other side.
I adjusted the brakes when I got it and everything was good for a short time then they got out of adjustment. There was a slight pull, probably not as noticeable on the rear than it would be on the front.
I had to take the adjusters off and take the cap off and then saw the that the L was on the Rt. side and the R was on the Left.
