Carb Issues
Old Sep 18, 2015 | 10:20 AM
  #61
ctubutis's Avatar
ctubutis
I am still going to want to know what a timing light says regardless of how things can be adjusted via other means... the "other means" are great when you're starting with a known-good and working configuration, but we don't have that here; for all we know, his base timing has him at 20° BTDC and the advance mechanisms are trying to push it into the forties.
But a good point has been brought up, that being that hose harmonic balancers (which are two pieces held together by rubber) can slip, resulting in incorrect readings.
Which means that this stuff needs to be verified, something that should be done IMO anyway... put #1 at TDC on the compression stroke and verify the pointer shows 0°.
Ignition timing is one of the basics that needs to be verified when attempting to tune an engine... all the engine needs is fire, fuel and air to operate... but it needs them in the correct proportions at the correct times... so check the basics....
"My printer won't print!"
"Is it plugged in? Turned on? Is there paper in it?"
Old Sep 18, 2015 | 11:27 AM
  #62
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Question, do you know which plug is #1? Ford is different from almost everyone else (Mercedes-Benz matches Ford for cyl numbering). It is the front passenger side cyl, right behind the alternator. If you have a 15/16" socket and a breaker bar and short extension, get under the truck and turn the engine while wiping off and looking at the balancer. You should find a set of markings from + 30° to -10° on it. Highlight +10° and 0° TDC. There is a pointer, somewhat buried, on the passenger side of the timing cover.
To find TDC, take an old spark plug, knock the ceramic out of it. Thread it inside for a 3/8" bolt. Take a long enough bolt to reach into the cylinder and lock it with a nut. Put this in place of either #1 or #6 (second one on driver's side) and CAREFULLY turn the engine with the socket until it stops. Mark the balancer, then turn it backwards until it stops again. Mark the balancer, TDC is exactly 1/2 way between the two marks. If it isn't on 0° TDC, then the balancer is bad and should be replaced.
If you find this and need to try to set the timing, use a piece of paper to transfer the 0 - 10° distance so you have a 10° BTDC timing setting.
Old Sep 18, 2015 | 03:36 PM
  #63
Ken Blythen's Avatar
Ken Blythen
Exactly. It's not possible to verify TDC accurately otherwise - even with a dial gauge, because of the few degrees of rotation at TDC with no piston movement.
BMaeder1
23
Jul 18, 2019 01:23 PM
benbuilder
20
Mar 2, 2016 09:29 PM
LongRider
Apr 16, 2010 07:35 AM
65jim
20
Mar 23, 2010 05:40 AM
CodaSmog
Feb 20, 2004 08:12 PM
