Boost detector issues
Old Sep 1, 2015 | 09:04 PM
ciscofreak's Avatar
ciscofreak
At the risk of looking like an idiot, I cannot for the life of me figure out why my boost detector will not build more than 1lb of pressure? I hear the air escaping from the passenger side exhaust manifold/up pipe joint area. How is the air getting to the hot side of the system? Could it be a wastegate issue? Am I overlooking something simple? Thanks for the help!
Old Sep 1, 2015 | 09:11 PM
binuya's Avatar
binuya
Crankcase? It's not in the picture but it looks like you still have the CCV hooked up.
Old Sep 1, 2015 | 09:12 PM
ciscofreak's Avatar
ciscofreak
I'm an idiot.
Old Sep 1, 2015 | 09:18 PM
Thomas White's Avatar
Thomas White
Originally Posted by ciscofreak
I cannot for the life of me figure out why my boost detector will not build more than 1lb of pressure? Could it be a wastegate issue? Am I overlooking something simple?
I'm just tossing some things out....
It could be your Wastegate. Have you inspected it?
I assume your being supplied with Shop Air of 90-100 psig and regulated down to 15-20 psig? It requires quit a bit in reserve to maintain flow.
You're using paired fittings on the Cap and Air Line?
You could have a blockage in the fitting itself on the Cap.
It could also just be a leak at a couple of your CAC Boots or perhaps the CAC itself.
I would suggest just looking around real good beginning on the intake side (which hardly ever leak - but you never know).
Sorry I couldn't be of any more help.
Old Sep 1, 2015 | 09:19 PM
Thomas White
Good Eye!
Old Sep 1, 2015 | 09:25 PM
ciscofreak's Avatar
ciscofreak
Yeah Thomas I forgot about the CCV!
Thanks for the help guys. Time to head back out to the shop.
Old Sep 1, 2015 | 09:27 PM
binuya's Avatar
binuya
I'm an idiot.
No. Pretty common oversight.
Oldanvilyoungsmith
19
Apr 27, 2017 07:16 AM
dmanshane
Jul 28, 2012 12:44 PM
Highridge
Aug 18, 2010 08:58 PM
60RatRod
17
May 6, 2010 02:20 PM
mndiesel
17
Nov 5, 2007 06:04 PM
