What Lies Beneath....
Old Aug 31, 2015 | 03:49 PM
psycoreefer's Avatar
psycoreefer
Wondering what if anything you guys have added, hidden, and installed beneath your truck. I was specifically looking at the vast and relatively easy to access space that exists between the rocker panels and the Frame.
I've seen a few air compressor setups in that space...
I'm thinking I'd like to put some sort of storage under there, but I'm not sure what yet.
Old Aug 31, 2015 | 03:56 PM
LivingLarge's Avatar
LivingLarge
Storage? Dead body storage? What lies beneath the movie? Psyco... What?
This thread looks interesting already! I just have the boring air compressor 2 actually, air tank and horns.
7.3Excursion4x4's Avatar
7.3Excursion4x4
I also put my compressors in there, but I'm thinking of moving them.
Old Aug 31, 2015 | 03:58 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Wouldn't be a bad place for some airtight bug-out storage cases or something similar. Possibly store spare parts and stuff in there with associated tools for things like the CPS, spare fuel filter, etc. I know the center console is plenty large, however mine is filled with toddler SHTF items.
Old Aug 31, 2015 | 04:06 PM
WE3ZS's Avatar
WE3ZS
There are also the van frame mounted battery boxes for those looking for additional battery mounting solutions.
https://www.ford-trucks.com/forums/1...ttery-box.html
I think RACERX7775 and Housedad both use either these battery trays or similar aftermarket units.
Old Aug 31, 2015 | 04:09 PM
WE3ZS's Avatar
WE3ZS
Why? I like your install and planned on something like it if I ever get an OBA system. Too much road spray, grit and junk getting to them?
Old Sep 1, 2015 | 11:55 AM
psycoreefer
More or less exactly what I was thinking - a great place to store stuff you want along but hope to not need. I've also got a bunch of recovery gear, straps, shackles, chains, a trench shovel, etc. that I almost never use, but I know that as soon as it isn't 'in' the truck I'll need it. I was thinking to keep it simple maybe a few lenghts of 6" PVC with a screw on cap at each end, then hose clamped to the frame.
I also like the air pump mount - looks very nice. At first I was thinking WTF - got enough bolts on the edge there! Then I realized in the other picture that its on a piece of piano hinge so you can swing the plate down to access the pumps - nicely done!
Old Sep 1, 2015 | 11:59 AM
Immortal_Ben's Avatar
Immortal_Ben
I have often thought about this. I have a tendency to pack a lot of weight in the truck as it is. Adding storage for parts is an idea I like, but I think I need an engine refresh first.
Old Sep 1, 2015 | 01:27 PM
devovino's Avatar
devovino
I had often thought about adding a natural gas/propane delivery system to an EX, to be able to run on both. I saw a section about it on the main menu but have not dove into it, just a thought. Not necessarily to gain more HP, but to extend the cruising range, maybe better the fuel economy, and this might be an area for a tank to be plumed in? Might have to bounce over and check out that section.
I know NG/propane does not create as much power per pound/gallon, but have always considered it...
jdadamsjr
Oct 21, 2014 06:40 PM
kittyhawksurf
Jun 9, 2009 07:11 PM
landcruzr
Jan 8, 2009 08:57 AM
lusher21
27
Nov 17, 2006 07:00 PM
F150daniel
Aftermarket Products
Oct 14, 2003 08:11 PM
