6.2L V8 Discuss the 6.2L V8
Mid grade towing
Old Aug 31, 2015 | 08:39 AM
Good listener's Avatar
Good listener
Mid grade towing
Has anyone compared mid grade fuel to regular for towing mpg? I filled up with 30 gallons mid grade on the last trip and calculated an increase of 1-1.5 mpg over the last trip. I used it again for the return leg and the results were the same. The days were calm and the routes were the same. The price difference has dropped to about 10 cents for some reason, so I thought I'd give it a try. Our truck just turned over 5000 miles and I have read where folks begin to notice a difference after reaching that mileage. Just wondering if the fuel was the factor or maybe something else like break in wear.
Old Sep 1, 2015 | 06:55 AM
spud57's Avatar
spud57
Didn't do the math but is the MPG savings greater than the add'l cost of the mid grade?
Old Sep 1, 2015 | 07:40 AM
Good listener
Amounts to about a 3% savings using the mid grade at the current price difference. Mid grade is cheaper now for some reason. Prices fluctuate a lot this time year as the stations switch over to winter blend. Some stations occasionally sell it for the same price as regular. I did not notice any significant change in performance with the mid grade. Just wondering if anyone else found an improvement in using mid grade. I really haven't noticed any change in any non-towing vehicle I've owned.
Old Sep 1, 2015 | 10:29 AM
SWV10's Avatar
SWV10
Here I use mid-grade (88) as 87 isn't available (86), then 91 when I fill up the toys.
I have used the 86 here in my then F150 and the mpg did go down by 4, the worst results for mpg was using E85. E85 is around 55 cents cheaper per gallon than the 88 but it turned out it cost me a tad more using the E85 because of the big loss in mpg Vs the 88 octane Gasoline.
Old Oct 19, 2015 | 10:24 AM
wrvond's Avatar
wrvond
It's entirely possible. The problem lies in the variety of gasoline blends on the market. Shell's mid-grade is not likely to yield the same results (for your vehicle) as Exxon's mid-grade for example. Of course the different formulation between grades of the same manufacturer will yield different results as well.
Maybe it burned more efficiently. Maybe it cleaned your injectors, making them more efficient.
Point is, there are too many variables to be able to make a blanket assessment (though the paradigm is that higher grade fuel is all around better for your vehicle) concerning performance in all cases.
Anecdotally - I used to commute between D.C. and West Virginia every week-end. In D.C. I filled my Jeep up with Exxon regular; I would arrive in West Virginia with 1/8th tank to spare. On the return trip I filled up with Go Mart regular, and would have to stop outside of D.C. to fill up again in order to make it home. It was clear I got better mileage with the Exxon branded fuel.
The best thing to do is, when you find a brand and grade that your truck runs well on, stick with that.
MidMichigan
6.7L Power Stroke Diesel
13
May 15, 2012 09:57 AM
DBLX
2009 - 2014 F150
16
Jan 18, 2012 05:23 PM
mbw919
2004 - 2008 F150
Sep 10, 2007 07:28 PM
12secondstang
Sep 25, 2006 03:30 PM
electod
May 10, 2005 12:10 PM
