Why does it keep over heating
Old Aug 30, 2015 | 09:45 PM
ClassicINf250's Avatar
ClassicINf250
Need some help yall, my 1980 f250 inline six keeps over heating, has happened twice now which is more than enough to for me. I recently changed the head gasket and pretty much every other gasket on the truck. But that's about it...after the last time I changed the thermostate since I thought that was the likely source. Been driving it on and off for the last 2 weeks with no issues. Now it did it again. Not sure what to do or what to check now. Could it be the radiator? Or something else? Any ideas thanks
Old Aug 30, 2015 | 09:51 PM
1984f1504x4's Avatar
1984f1504x4
check coolant/ water levels and check water pump, radiator lines/hoses, etc my 302 did that until i found a pinched copper line that i then replaced and now it runs fine
Old Aug 31, 2015 | 08:26 PM
ctubutis's Avatar
ctubutis
<p>How do you know it is overheating? Is there steam coming from the front recovery bottle or sumthin'? Or are you relying ob the factory gauge to tell you the truth?</p>
Old Sep 1, 2015 | 05:37 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Originally Posted by ClassicINf250
Need some help yall, my 1980 f250 inline six keeps over heating, has happened twice now. I recently changed the head gasket and pretty much every other gasket on the truck. But that's about it... Any ideas thanks
When you had the head off, did you have it checked for warp or cracks?
Old Sep 1, 2015 | 08:43 AM
Franklin2's Avatar
Franklin2
Yes, we need more explanation. Is it overheating on the road or around town? And like Chris said, why do you think it's overheating? If it's just spewing out coolant, that could be just a faulty radiator cap.
Old Sep 1, 2015 | 09:05 AM
InfantryCPT's Avatar
InfantryCPT
or a nice big air bubble in the system, after you replaced the head gasket. or faulty temp sensor
Old Sep 1, 2015 | 02:38 PM
1986F150six's Avatar
1986F150six
If depending on the factory gauges, your engine may not be overheating. The factory gauges can be less than accurate. See if you can borrow an IR thermostat from a mechanic or parts house. With the engine at operating temperature, point the thermometer at the thermostat housing and see what the actual temperature is.
Old Sep 1, 2015 | 02:52 PM
ClassicINf250
The truck looses power and yes steam and pressure are shooting from the recovery bottle. The factory gauge does say it's over heating but after I notice the power loss and steam.
Old Sep 1, 2015 | 02:53 PM
ClassicINf250
No I didn't, getting ready to move and didn't have the time...nothing obvious that I could see
Old Sep 1, 2015 | 05:22 PM
ClassicINf250
I replaced the radiator cap...so that should be good. Thought I got the bubbles out of the system but I might need to play with that some more. Thought about getting aaftermarket gauge and seeing what that reads.
It over heats when I'm driving on the interstate. Seems to do fine around town.
Old Sep 1, 2015 | 05:27 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
Overheating
A radiator pressure test may be in order. any idea on the age of the radiator? or the thermostat?
Old Sep 1, 2015 | 05:36 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I would have the coolant chemically tested for combustion byproducts.
This is a simple and foolproof way to be sure it is not the head or deck.
Old Sep 1, 2015 | 05:44 PM
WhatsAChevy?
OK....duh.....re-read and seen You replaced the Thermostat. Still wondering about the radiator.
Old Sep 1, 2015 | 08:21 PM
ClassicINf250
Yea...Friday I am off so my plan is to try a few of these suggestions. How many gallons of coolant does the system hold?
Old Sep 2, 2015 | 09:37 AM
1986F150six
I would say close to two gallons. If you can park on an incline with the front up, it will assist with the bubbles.
joekacker
Jun 14, 2012 11:00 PM
sheandsar
Feb 20, 2012 03:58 PM
qmcdugan
Nov 9, 2006 10:53 AM
BLstangin
Jul 6, 2005 06:58 AM
Border3899
Jul 11, 2003 01:28 PM
