Sponsored by: Auxito
antenna to long
Old Aug 2, 2003 | 02:29 PM
tfrazee's Avatar
tfrazee
Question antenna to long
I am wondering if anybody has come up with any clever suggestions to shorten the height of the factory antenna. I park in a parking garage now and my 4x4 f-150 hits every freak'n support. I know that the antenna is a fiberglass core with the wire wrapped around. I don't think that you just cut it. Any help would be great. Thanks.
=-Tim
Old Aug 2, 2003 | 05:16 PM
AegisSailor's Avatar
AegisSailor
antenna to long
An antennas length is determined by the frequency that it is designed to recieve. So the short answer is that no, you just can't cut it.
You can probably find an after market antenna to fit your size requirements though. A "loaded" antenna is on in which part of the antenna wire is coiled around the base so you still get the proper length of wire but it's packaged in a shorter antenna. Most CB antennas are of this type.
Old Aug 2, 2003 | 11:09 PM
aldridgec's Avatar
aldridgec
antenna to long
I don't believe that its fiberglass.
The "wire" is to disrupt air flow around the antenna to keep it from whistling.
Chris
Old Aug 3, 2003 | 06:05 PM
Aftrmidnite's Avatar
Aftrmidnite
antenna to long
Ford sells a shorter antenna, that will look like the stock one.
Old Aug 8, 2003 | 08:34 PM
fordman19762003's Avatar
fordman19762003
antenna to long
I cut about 3'' off my antennta so it would clear my garage door and it works just as good as before.
Old Aug 12, 2003 | 03:47 PM
tfrazee's Avatar
tfrazee
antenna to long
I trimed abou 3 inches off of my antenna last night. Drove around his morning and could still get the stations that my home stereo has a hard time getting.
Reception is as good as before. I know that the lenght of the antenna is very important, but with the freq that we're working with and the nature of FM stereo broadcasting, I doubt it makes very much difference.
Now CB antennas are a whole other story.
Old Aug 14, 2003 | 11:52 PM
mountainman's Avatar
mountainman
antenna to long
so what if ur attenna hits the beams, mine does, why did that bother u? its a good height checker so u dont hit ur roof. lol
Old Aug 16, 2003 | 07:55 PM
dcd's Avatar
dcd
antenna to long
Well, my antenna not only hits beams in the parking garage, but also hits the florescent shop lights in my garage. So I need something shorter. Instead of shortening mine, I bought a shorter billet aluminum antenna. If I go on a road trip and need better reception I still have my original antenna to screw in.
