looking for frame replacement info
Old Aug 30, 2015 | 05:57 PM
86f150step's Avatar
86f150step
hello all,
got a project going its a 83 stepside 4x4 previous owners botched the frame with bad welding and cutting but what im looking for is would a 6' 2wd frame fit under the truck of course id want to bolt in all the 4wd goodies is there any big differences other than the cross members thanks
Old Aug 30, 2015 | 07:51 PM
Diesel_Brad's Avatar
Diesel_Brad
You will want a 80-91 reg cab short bed 4wd frame
Old Aug 30, 2015 | 08:17 PM
86f150step's Avatar
86f150step
Only reason I'm asking about the 2wd frames is Ive seen a bunch of them in great shape
Old Aug 30, 2015 | 09:15 PM
Franklin2's Avatar
Franklin2
2wd trucks are great for body parts also. They where usually not driven much in the salt.
Old Aug 30, 2015 | 09:53 PM
1984f1504x4's Avatar
1984f1504x4
i have a 1986 f150 reg cab short bed 4x4 frame with axles if you're interested
Old Aug 30, 2015 | 10:02 PM
86f150step's Avatar
86f150step
I was just figuring since I got the correct 4x4 items that they may bolt in factory holes because Ive heard people converting 2wd to 4wd
Old Aug 31, 2015 | 02:55 AM
4x484150's Avatar
4x484150
Crossmembers will be the same, only differences are the rear leaf spring brackets. 2wd used 2.5" wide springs, and 4x4 used 3" wide springs. You have 3 options:
1) If your current hangers are not rusted out, try to reuse them.
2) Use the 2wd springs and hangers
3) Buy aftermarket hangers (Dorman has them, but only the rearward ones for F150 in 3" wide)
Old Aug 31, 2015 | 09:22 AM
ATS Junior's Avatar
ATS Junior
SPONSOR
If you do go the route of replacing the hangers, we have both the front of rear and rear of rear position hangers. I may be wrong but I believe the mounting holes on the rear of the rear hanger is the same pattern and measurements for the 2.5" and 3" wide. So that's one less thing you would have to worry about..
-Junior
Old Aug 31, 2015 | 02:27 PM
4x484150's Avatar
4x484150
Right, the actual bracket will be the same for 1980-1996 U/F100/150-F350 the most rear position, its the shackle that will be different.
I was referring to the front bracket, where the space for the leaf goes may be different between the 4wd and 2wd.
I haven't been to a parts store to compare them side by side.
Old Aug 31, 2015 | 02:41 PM
Franklin2's Avatar
Franklin2
The rear spring bracket and the front are different. The 4x4 uses 3 inch wide springs, so the hangers are wider. I did modify a 2wd rear spring bracket to fit a 3 inch wide spring, but it took a little welding to do it.
Old Aug 31, 2015 | 02:46 PM
ATS Junior's Avatar
ATS Junior
SPONSOR
^^^^ What he said. I was only referring to the actual center to center hole measurements of the (4) holes that go to the frame. Wider spring on the 4x4. The front of the rear hanger will be completely different also.
Old Sep 8, 2015 | 07:53 PM
86f150step's Avatar
86f150step
Thanks for the info found a donor gotta charge up my cordless 1/2 impact and have at it
1966f250
Mar 18, 2015 06:37 PM
shamineaukyle
Jul 7, 2010 11:07 PM
78ford351m
Jul 23, 2006 03:01 PM
BobbyFord
Sep 28, 2005 10:15 PM
fenceguy
New Hampshire Chapter
Feb 29, 2004 11:54 AM
