Frame interchange
Old Sep 28, 2005 | 04:07 PM
BobbyFord's Avatar
BobbyFord
Frame interchange
Is a '63 F250 4WD frame the same as a '63 F100 2WD??
Anybody know?
Old Sep 28, 2005 | 08:19 PM
Highboy4x4's Avatar
Highboy4x4
I beleive the frames are quite different as the 4WD is straight from the front to rear of the frame with no dips or bends in the frame under the bed and the 4WD is also thicker to accomadate the transfer case. The wheelbase is different also as the 4WD is 120in and the 2WD has a 122in wheelbase. I have both frames to check for certain for you if you need me to make certain on these issues but I am 99% sure they are very different. By the way, I am restoring a 1964 F100 4x4 at the moment (and nearly completed) if you have any other questions you may need answered. Hope this info. is helpful to you. Lewis
Old Sep 28, 2005 | 10:15 PM
BobbyFord's Avatar
BobbyFord
Thanks for the reply.
I'm looking for a straight frame to modify, but I want to make sure I get the right one.
