Rear Floor pan question
Old Aug 30, 2015 | 04:16 PM
Jmanb13's Avatar
Jmanb13
Hello all, I am a new member here and I wanted to ask my first question.
I just got a 93 E250 cargo van that was previously a commercial van. As I was cleaning it, I noticed that the last few feet of the floor as it gets to the rear has a little bit of a dip to it. Is this normal in the floor or is this something bent that I need to look at correcting before I carry on with making a floor for the van?
Picture below shows what I am talking about.
Old Aug 30, 2015 | 04:57 PM
econolinemanor's Avatar
econolinemanor
That's not normal, looks like it's seen some pretty heavy loads. Reminds me of a small Fork Lift setting in Wooden Pallets and then being pushed forward and then dragged back out. I would check the Body Mounts for damage before any projects get started.....................
Old Aug 30, 2015 | 05:28 PM
Jmanb13's Avatar
Jmanb13
The picture angle might make it look worse than it is. Where the body mounts are is not bent, but in between each cross brace the sheet metal has a dip in it. Almost like something heavy sitting in between each cross brace. So if you were looking at it from the side it would look like a series of W's \/\/\/ where the low points are the unsupported areas of the pan and the top parts are where the body mounts and cross braces are.
The company the vehicle came from was a service vehicle for a printing service and sales company so it carried commercial office printers and components. I doubt there was anything more than a couple hundred lbs in the vehicle at any time.
Here is a shot from underneath where the body mounts are. You can see the dip in the sheet metal between the body mounts. The body mounts look good to me, but I'm not a body mount expert
Here is a shot from a lower angle where you can see how it dips in between each cross brace.
Old Aug 30, 2015 | 05:55 PM
econolinemanor
Anything is possible, but in the first pic I see the lower half of the rubber mount darker "cleaner" in color and that probably how much weight it was carrying. That's a pretty good load.....maybe couple hundred pounds per square inch to bend the floor................Pallets of Printer Paper?
Old Aug 30, 2015 | 07:01 PM
Jmanb13's Avatar
Jmanb13
The printer company only does printers and toner plus software for managing documents so no pallets of paper.
The bottom of the mount may be cleaner because I used a power wash to clean all the crap off the van and that mount was probably hit from the sprayer since it is right behind the rear wheel.
Assuming the actual frame isn't messed up, it would just be bent floor pans though correct? I'm assuming it shouldn't be any problem putting some plywood or similar down to make a floor? I would of course clean it up and protect the metal from rusting first however.
The 6th pic (3rd pic in post #2) in this thread has a similar dip right behind the rear wheels similar to the one i'm seeing on my van.
https://www.ford-trucks.com/forums/1...ough-pics.html
Old Aug 30, 2015 | 07:24 PM
vettex2's Avatar
vettex2
I've seen that in literally hundreds of vans. I wouldn't sweat it.
Old Aug 30, 2015 | 08:05 PM
econolinemanor
It's not that bad, but any leaks or Night sweating might leave puddles under the Plywood depending on your Area................
Old Aug 30, 2015 | 10:37 PM
vettex2's Avatar
vettex2
drill a hole then
Old Aug 31, 2015 | 01:23 PM
kynnhoj's Avatar
kynnhoj
I can see the pavement when I lift up my carpet....(Midwest rustbelt)
You have nothing to worry about.
desmond53
54
Nov 20, 2024 05:36 PM
rizob01
Jul 18, 2018 11:58 PM
Lima0331
Mar 2, 2017 02:17 AM
CamaroAdam73
Paint & Bodywork
Nov 10, 2011 10:24 PM
Phantom
Apr 24, 2007 01:36 PM
