Lower ignition rod actuator removal ?
Old Feb 28, 2002 | 04:57 PM
fiveptO's Avatar
fiveptO
Old Feb 28, 2002 | 08:59 PM
trapfox1's Avatar
trapfox1
The lower ignition rod actuator broke in my 1990 F150 w/
auto and tilt wheel. I have the steering wheel off, turn signal
switch removed, upper cover casting off, lower casting loose
ect. I cannot figure out how to get the tilt mechanism apart to
get the actuator out of there. There are two pins or bushings with
threads running through the center that hold the "u-joint" of the
tilt column together. Do I take these out to get at the actuator? If so, how do I do it? Any help on how to install this would really help.
Neither Haynes or Chilton describe this procedure.
Old Feb 28, 2002 | 09:21 PM
nitro94's Avatar
nitro94
Yes you need to remove the two pivot pins. Then the locking lever needs to be moved off the tilt locating pins and then you can exchange the actuator. There is a special tool for the pins but sometimes you can find a bolt that will screw in the threaded area and use pliers to pull the pins.
Old Feb 28, 2002 | 11:09 PM
Electric1's Avatar
Electric1
The holes are either a 8x32 or 10x32 screw. not sure which but it won't make you go broke buying one or two of each.
Electric1
Old Mar 1, 2002 | 12:43 AM
brett_d's Avatar
brett_d
Actually it is a 6mm .20 or .25 pitch bolt. they are not in there that tight and are easily removed!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
