'91 Cab rust repair
Old Aug 28, 2015 | 09:29 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
'91 Cab rust repair
Thought I'd document my attempt at doing a rust repair on my single cab truck. The driver's side is actually worse and will require replacing everything on the lower door frame. The passenger side isn't as bad so I'm actually doing that one first before the tin worm gets any more.
Most of the rot is cut out at this point. I etched it and power-washed. Here's where I'm at as of this evening...
Old Aug 29, 2015 | 01:46 PM
Vadis's Avatar
Vadis
Got pretty much similar rot on mine. Looking forward to checking out the work.
Old Aug 30, 2015 | 09:01 AM
tjc transport's Avatar
tjc transport
i ain't rite
my passenger side looks like that on the 88, the driver side is missing about 6 inches after the rocker panel fell of last fall.
i am replacing the cab instead of messing with replacing that much metal. it will be easier and faster than trying to repair it.
Old Aug 30, 2015 | 09:25 AM
Diesel_Brad's Avatar
Diesel_Brad
Make sure you get out your sandblaster
Old Aug 30, 2015 | 09:52 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
That would probably be the smarter idea for me too, but instead I'll use this as an excuse to practice my welding "skills".
Eastwood Rust Converter applied all over and then first chunk of angle iron spot-welded in place and then top-coated with Wurth weld-through primer. I'll MIG the angle iron in today for better structural integrity (spot-welding doesn't work well with such dissimilar thicknesses of metal).
Next piece of angle iron test-fit in place. Need to strip off the paint before using. "Free" angle iron has a price . The application calls for a tiny bit more than a 90-degree angle, but I'll make this work.
Old Sep 1, 2015 | 12:53 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Whoever said re-using bed-frame angle iron was a bad idea for a welding requirement was right. Spot-welding was okay, but I had a lot of trouble using the MIG with this stuff. And yes, I did remove the paint, on all sides, at least with the first piece.
So I quickly punted and turned this into a bonding project. At least the first piece, the longest one, was welded in place - mostly spot-welds, with a few ugly MIG welds here and there.
Here's where I'm at now - two long pieces sorta back-to-back and one piece about 7" long.
Old Sep 1, 2015 | 01:00 PM
tjc transport
i ain't rite
<p>are you using shielding gas and a 220 volt mig, or flux wire and a little 110 volt mig.</p><p>the size of the machine and wire used makes a BIG difference.</p>
Old Sep 1, 2015 | 01:35 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
It's a larger (145 Amp) 110V unit using flux wire. Your point is taken, but I've used it with metal of this thickness before. This angle iron just didn't want to melt.
Old Sep 4, 2015 | 03:48 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Time to get this finished. It's just a beater-truck after all...
Everything etched, power-washer, then allowed to dry 48 hours before sealing with Mastercoat Rust Sealer. Mastercoat Rust Sealer
Back corner. Not much corrosion going on here, but prevention is way easier than cures...
Old Sep 4, 2015 | 04:06 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Seams sealed with Wurth Seam Sealer...
And then top-coated with Red Devil Chinese Red enamel...
And no, that's not a very good color match, but that's okay. Function following form here for sure.
I didn't bother with adding the sill that had completely corroded away. It's primary purpose along the bottom is to hold the weather-stripping. Maybe I'll just glue that in place.
For now I'm going to leave it just like this so I can easily monitor the area in the front and treat further if needed. It's structurally sound again and I've halted the rust's advance. I've also done a bunch of preventative work on the bottom-side of the floor on this side - etched and hit with Mastercoat.
Not a perfect repair by any means, but sometimes "good enough" is just that.
Old Nov 29, 2016 | 05:13 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
History repeated itself on the driver's side. I welded a bit before realizing that my bonding skills were much better than welding. But I was already committed to sectioning in pieces, so just took that same approach with screws and glue. Sealed it all with some more Mastercoat.
I'll get around to replacing the rocker section in the spring. At least now I've got a more stable and solid floor to work with.
Old Nov 29, 2016 | 05:27 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Here's the "before" shot...
Old Nov 29, 2016 | 07:42 PM
toby tough's Avatar
toby tough
Flintstones brakes. Ha Ha.
Old Nov 30, 2016 | 11:10 AM
Diesel_Brad
The photo is priceless
Joejustatruck
Jun 3, 2014 09:44 AM
Rambo76
Jan 3, 2009 05:20 PM
4-fords
Paint & Bodywork
15
Sep 22, 2006 09:05 PM
steve butera
Paint & Bodywork
Jan 12, 2004 11:40 PM
lars
Mar 10, 2000 03:21 AM
