Aerostar Ford Aerostar
adding trans cooler
Old Aug 28, 2015 | 04:40 PM
zenish's Avatar
zenish
adding trans cooler
about a month ago my van did the thing where it dumped four quarts of trans oil onto the exhaust creating an awesome smoke screen.id like to avoid this happening again.i plan on adding a second trans cooler in series with the factory one.any reason this is a bad idea?anyone know if the trans fluid goes through the radiator or trans cooler first?
Old Aug 28, 2015 | 07:48 PM
96_4wdr's Avatar
96_4wdr
Changed mine years ago for heavy towing.
Bypassed and capped off the radiator tank cooler, they leak into the ATF and tranny killing the tranny.
Put the largest plate and fin cooler available in front of the radiator with an inline ATF filter.
Bypassed the old ATF tranny small cooler at the bottom of the radiator and turned it into a power steering cooler with another inline filter.
All still running original OEM tranny and PS.
Use only full synthetic ATF in these, Mobil 1.
Tube coolers are inefficient and worthless, will overheat an Aero.
Old Oct 17, 2015 | 05:23 AM
zenish's Avatar
zenish
do you know the parts number of the cooler you used?i want to get the biggest one that installs easily.
Old Oct 18, 2015 | 03:42 PM
96_4wdr's Avatar
96_4wdr
One I used is 12 x 11, can't remember if it's 3/4" or 1 1/4 thick. Measure your radiator space for your application.
Tru Cool is the best on the market, has proprietary thermostat ATF flow control so tranny warms up quickly in cold weather.
Tru-Cool LPD Transmission Oil Coolers. Protect Your Investment?and Your Warranties. | Tru-Cool
Never had any problems with mine overheating, tranny or engine since putting it in, 15 years ago. Bypassed and blocked off the cooler in the radiator side tank, prevents a leak of coolant into the ATF =s tranny death.
added filter
http://www.ebay.com/itm/like/261385396200?ul_noapp=true&chn=ps&lpid=82
electryc_monk
16
Jan 28, 2018 07:56 AM
GoldCo
Nov 26, 2017 01:39 AM
BDalton
Feb 9, 2009 08:49 AM
BIGFISH70
Jun 19, 2007 10:07 AM
cookkd
Aerostar
Oct 5, 2005 08:57 AM
