what heat range autolite plugs for mid 70's 460 w/elec ign?
Need to replace the plugs in the 460. I think it's out of a lincoln, 73 to 78 (that's the closest we could I.d. it). Anyways, it's got electronic ignition, the box is a parts store replacement for same time period. Wires are 7mm parts store. It had autolite 26's but they're fouled.
Shouldn't ever really need to change heat range from factory spec.
Maybe if you spend all of your time speeding across Nevada and Death Valley in July as part of your daily routine. Then go one step down to a "colder" plug.
But, if stock OEM plugs are fouling then something else is at fault, NOT the plugs.
77frd
03-16-2012 06:00 PM
Omeagher460
05-03-2008 11:08 PM
mean green2
10-27-2005 07:36 PM
