Sponsored by: Real Truck
2001 7.3 no speedometer
Old Aug 27, 2015 | 09:53 PM
cali_7.3's Avatar
cali_7.3
First of all, I've spent a ton of time on this site reading from the shadows and your guys' help has helped a ton. I have a 2001 F-250 with the easy stuff done (exhaust, 6637 intake, gauges, edge juice-will be gone soon for a DP). The truck speedometer doesn't work all the time but seems to work every once in a while. I've changed out the vss and the front right abs sensor because the line was cut but I'm still having the same issue. The thing that stumps me is if I get the truck up to 70mph or above the speedo will spring into position and then work up until I stop and then the issue starts again. I have a snap on scanner and I'm not seeing any codes at all and everything is testing out good so far. If anybody has an idea can chime in and point me in the right direction I would really appreciate it.
thordehr
19
Nov 22, 2010 11:09 PM
k4uwc
Sep 28, 2009 07:58 PM
davidcam
Mar 21, 2008 08:47 PM
toolebox1
Oct 26, 2006 10:15 AM
Slackeyed
1997 - 2003 F150
23
Jan 7, 2006 08:36 AM
