Sponsored by: Real Truck
Battery dilema
Old Aug 26, 2015 | 11:26 PM
Stangrcr1's Avatar
Stangrcr1
Battery dilema
First, 2000 F250 4x4 Powerstroke. Have owned this since new. Back in 2006 I bought a pair of Optima Red Tops and they have been in the truck ever since. Yes, they are in there now, but they won't hold enough charge after a few days to start the truck. I have a charger on them now so I can use it tomorrow.
I know Optima moved production years ago to Mexico, after I bought mine, and had a lot of bad batteries. Has this changed? Are the Optimas out now just as good as the old ones? If not Optima, what is a good option?
Any help appreciated!
Old Aug 27, 2015 | 05:07 AM
rjcorazza's Avatar
rjcorazza
I was not aware of a quality control issue with optima. I hope they have resolved any issues, as I recently installed optima batteries in my farm tractor and diesel zero turn. The red top in the tractor lasted 11 years.
Old Aug 27, 2015 | 10:42 AM
F3504ME's Avatar
F3504ME
The new Optima's are not what they used to be.. many issues on them recently. Personally, I purchased a brand new one off the shelf, got it home and it would not hold a charge.. Took it back and got a "normal" battery..
Almost 10 years out of any battery these days is great, they are likely just worn out..
I would not think red tops would have enough oomph to start a diesel..??
Old Aug 28, 2015 | 07:37 AM
Thor'sHammer's Avatar
Thor'sHammer
Batteries plus has their own brand of remanufactured dry cell batteries that I've had good luck with in the past. My opinion though, you can't go wrong with a lead acid battery. My last set lasted 10 years and one of them was still testing good when I replaced both.
Old Aug 28, 2015 | 08:37 AM
speakerfritz's Avatar
speakerfritz
AGM's need about a half a volt higher charge rate than wet cells....so check your charge voltage.
also, if you have an aftermarket high amp alternator...check the at idle charge rate since a lot of high amp alternators produce little at low rpms.
Old Aug 28, 2015 | 11:59 AM
Chuck's First Ford's Avatar
Chuck's First Ford
also about aftermarket alternators...
some do not start charging till after the engine has exceeded its idle rpm for the first time after startup.
Milwaukee1979F150
Dec 12, 2011 03:36 PM
Bpayton
Sep 19, 2011 07:36 AM
thechief66
45
Jan 26, 2011 03:12 AM
rdbesq
Large Truck
Jan 13, 2011 10:19 AM
havns3
Jul 1, 2010 07:43 AM
