Fuel filters replacement
Old Aug 26, 2015 | 11:21 PM
Actechnician 71's Avatar
Actechnician 71
Well I just finished upgrading to the blue spring and replaced both fuel filters while I was at it. This is the 2nd time that I've replaced the filters since I've owned this truck. I don't remember there being 3 - 4 gallons of fuel that drained from the water fuel separator. Is that normal?
Old Aug 26, 2015 | 11:25 PM
87crewdually's Avatar
87crewdually
Not normal. Usually pint or so. Was the tank full or under pressure? It might of siphoned is the only thing I can think of.
3-4 gallons, that's alot.
Old Aug 26, 2015 | 11:33 PM
Actechnician 71
Yes the tank was full. Maybe that's why there was so much. I had a 5 gallon bucket under to catch the fuel and it just kept filling. I finally just went ahead and removed/replaced the filter thinking it would never stop.
Old Aug 27, 2015 | 07:34 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Half tank or less and park level or nose up.
Josh
Old Aug 27, 2015 | 07:40 AM
69cj's Avatar
69cj
I never had a problem 1/2 or full tank. Try removing the fuel cap to relieve any built up press. If that doesn't help you'll have to go Josh's idea but it shouldn't be required.
Old Aug 27, 2015 | 10:03 AM
MJMETHOW's Avatar
MJMETHOW
Changed mine many time's with full tank.Not a problem,I do open the cap.I also fold a absorbent pad and tuck it under the filter housing.Works better than a rag.
Bounds-Electric
6.4L Power Stroke Diesel
13
Jan 21, 2011 02:22 PM
powerstrokeredneck97
Nov 10, 2009 10:55 PM
Gary A.
Oct 12, 2009 01:02 PM
Tom D
Bio-diesel, Propane & Alternative Diesel Engine Fuels
May 18, 2008 03:24 PM
05f250fx4
Oct 11, 2006 08:09 PM
