door insulation
Old Jul 22, 2019 | 05:39 PM
dubya TF's Avatar
dubya TF
I'm using what's sold as a/c & heat duct insulation at Home Depot. The brand is Frost King with 24" x 15' rolls for $15-17 per roll. I prepped with wire wheel, scraper and a couple coats of POR15. Once that was dry, sprayed down both items with 3M adhesive and layed it in. Keep clear of the edges and bottom of the door. Cheap? Yes. Better than nothing? I think so but I'm winging this deal as I go.
Old Jul 23, 2019 | 05:24 AM
66v8baby's Avatar
66v8baby
I used Dynamat because I didn't want to do it twice. I've tried cheap knocks off before and was very disappointed. Anyway, I used 2 12x12 sheets on the inside of the outer door shell, three on the over head roof panel, one on the firewall lower edge, one and a half in the footwell, one on the removable trans tunnel cover and 3 under the seat. I also put reflective heat insulation completely covering the roof panels. Made an enormous difference! Almost as quiet as my Tacoma.
Old Jul 23, 2019 | 07:42 AM
AlsRyd66's Avatar
AlsRyd66
I'll jump in here. I used this product throughout the interior of the cab that I found on Amazon. Inner doors, cab rear, floor, firewall and roof. Pleased with it and has not peeled away or smell. If applied right with a roller, it ain't coming off by itself.
Noico 80 mil 36 sqft car Sound deadening mat, Butyl Automotive Sound Deadener, Audio Noise Insulation and dampening.
Old Jul 23, 2019 | 09:54 AM
jjriley97's Avatar
jjriley97
I do car audio systems and use the Noico as well. It is a great product and comparable to the Dynamat. Doors can be tricky, but there are affordable ways to do them. The attached Youtube video was put together by a reputable guy in the audio world and is geared toward sound competitors, but definitely could be used in the hot rod/classic car and truck world as well. I will be doing this to my truck.
Old Jul 23, 2019 | 02:04 PM
SixtyFour's Avatar
SixtyFour
I did/am in the process of doing what 66V8Baby did. Dynamat inside the doors, on the roof, firewall and floorpan. It helps a lot to take the ring/echo out of the panels and you get that nice solid door sound.
v6lightning
Jul 18, 2013 12:12 PM
I Love My Truck
16
Apr 8, 2011 03:22 PM
VanGo
Aerostar
Dec 14, 2007 08:32 AM
ford390gashog
13
Feb 8, 2005 11:04 PM
ejfitco
15
Jan 26, 2005 12:22 PM
