1948 Ignition replacement
Old Aug 25, 2015 | 07:43 PM
chrislynn5's Avatar
chrislynn5
1948 Ford F-6, Flat 6, I have a new ignition cylinder, and if need be I have a new ignition housing.
Does anyone have some instructions on replacing them? Should I do both? I got the parts from Dennis Carpenter, not cheap.
I didn't get the keys with my truck so I'm replacing it.
Much appreciated, and if there was a post I missed, please add the link.
Old Aug 25, 2015 | 09:35 PM
Mixer man's Avatar
Mixer man
I got the whole assembly from DC too. Keys and all. Didn't want to risk a bad switch.
Old Aug 25, 2015 | 09:39 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Can you explain how to install the switch?
I told the OP how it's done in a 51, but I don't know if they're the same.
Thanks.
Old Aug 25, 2015 | 10:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Part of it is in the manual. Replacing the cylinder itself was shown in some threads in the past, an Advanced Search should turn them up.
Old Aug 26, 2015 | 05:07 AM
fordf348's Avatar
fordf348
Following those instructions it is actually a simple task
Old Aug 26, 2015 | 07:00 AM
chrislynn5's Avatar
chrislynn5
This is a F-6 1948, it doesn't look like the illustration.
Old Aug 26, 2015 | 07:52 AM
FortyNiner's Avatar
FortyNiner
How is yours different? The manual illustrations are sometimes not the best - as this one would suggest that the smooth keyslot bezel has tabs extending from it, for example.
Old Aug 26, 2015 | 08:16 AM
chrislynn5's Avatar
chrislynn5
Please look at post ( https://www.ford-trucks.com/forums/1...f6-1948-a.html ) you can get a glimpse of it. I can post a better picture tonight if needed. Thanx.
Old Aug 26, 2015 | 10:00 AM
FortyNiner's Avatar
FortyNiner
Looks to me like your switch was previously replaced with a non-stock version.
Old Aug 26, 2015 | 10:21 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I used to have the same one, NAPA universal. The PO may have filed off the tangs in the dash to make it fit. You just unscrew the bezel to remove. Obviously your new cylinder won't work in it.
Old Aug 27, 2015 | 07:50 PM
chrislynn5's Avatar
chrislynn5
yep, you guys were correct. Someone had replaced the original one. I removed it, and found my new one was made for my truck. The only issue now is that I need the bezel Back to LMC. I matched the wires to the correct leads on the new ignition housing. I'm not sure how the cylinder fits in. It appears to lay in there and the bezel holds it all together?
Old Aug 27, 2015 | 07:56 PM
ALBUQ F-1's Avatar
ALBUQ F-1
On 51-52's there is a brass peg that holds the cylinder in.
Old Aug 27, 2015 | 07:58 PM
chrislynn5's Avatar
chrislynn5
is it part of the cylinder assembly do you know? Or extra. Any pics? Thanx.
Old Aug 27, 2015 | 08:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1
See below, I have several like this but one that's completely different. None say Ford on them??
You put the cylinder into the switch, then put the peg into the hole in the cylinder, thru the slot, to lock it in place.
Old Aug 27, 2015 | 08:29 PM
chrislynn5's Avatar
chrislynn5
makes sense, I'll check it out tomorrow when I have a chance. Thanx for the pic's they really help.
Steven Garcia
Aug 1, 2019 06:43 PM
Chefsteele
25
Jan 20, 2014 10:46 AM
70torino429
Jun 18, 2010 04:00 PM
