should I or not
Old Aug 25, 2015 | 11:20 AM
peka's Avatar
peka
should I or not
84 f250 351w I have oil pan off to replace it and a new pump, should I check torque on rod and main bolts while I'm in there?
Old Aug 25, 2015 | 05:22 PM
Gary Lewis's Avatar
Gary Lewis
It won't hurt. However, don't expect it to be exactly what your torque wrench says it should be. And, you don't want to change it, just ensure it is tight. So, I'd set my wrench light and sneak up on each one to see what my wrench says it is w/o turning it.
Old Aug 26, 2015 | 12:06 PM
peka's Avatar
peka
That was the plan I had until I decided to replace the rear oil seal (2 piece) on the crank, is there an easy way to do this without removing the crank? But now I discovered I have a 1979 block from a LTD with 1981 exhaust and intake, do not know about heads yet. Also all the pistons are marked with there weight and the rods and caps are numbered, somebody must have done a rebuild. And that's how I got the leaky oil pan, from a HV oil pump that was just a little to big and when the oil pan bolts were tightened it pushed against the oil pump until a crack developed in the pan.
Old Aug 26, 2015 | 05:39 PM
Gary Lewis's Avatar
Gary Lewis
You can replace a two-piece seal without removing the crank. I've done it but don't have the instructions handy.
Uni Moe
Dec 14, 2016 12:42 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Jan 28, 2015 08:36 PM
1979BEAST
Jun 22, 2012 02:22 PM
martyf150
Feb 4, 2003 11:28 AM
Seifferlein
Aug 15, 2002 12:37 PM
