Tranny spacers
Aug 24, 2015 | 06:35 PM
Tranny spacers
I have a 71 351w bolting up to a late model auto C-4. Does anyone know the correct spacer size. As well as a newbie question what side is the spacer on
Aug 25, 2015 | 05:49 AM
Would you share with us what you are referring to as a spacer?
John
Aug 25, 2015 | 06:48 AM
Between flexplate and crank i would be assuming i guess it would also be called a shim
Aug 25, 2015 | 09:49 AM
Aug 25, 2015 | 10:41 AM
Yes im not sure if its universal or different sizes
Aug 25, 2015 | 10:53 AM
That one is for 289/302/351W to C4. Those engines share a common bolt pattern and external dimensions.
The spacer goes between the block and the transmission. The crankshaft wouldn't be involved directly with the spacer I don't believe.
Aug 25, 2015 | 11:03 AM
Aug 25, 2015 | 11:37 AM
D2TZ-7007-A .. Engine Rear Plate - Is correct for the OP's application.
It's still available from Ford. MSRP: $94.12 / FTE Ford dealer parts dept sponsor silverstatefordparts.com price: $64.94 / Gaudin Ford - Las Vegas NV / Gaudin has 4 in stock.
derk001
Apr 6, 2012 11:11 AM
oricle
Apr 17, 2005 02:34 PM
cjben
Feb 13, 2003 05:50 PM
