C8 heads rocker arm issues
Old Aug 23, 2015 | 09:25 PM
John F100's Avatar
John F100
I am building a 1975 460 I pulled out of an old lincoln to drop into my pick up truck. I got a set of rebuilt C8 heads and bolted them onto my block. Everything is going together just fine, but today I tried to install my comp cams steel roller tip rocker arms and they fit very loose, like they flat out won't work. I had tightened them to 20ft. Lbs. And they compressed my valve springs and the engine wouldn't turn. Is this a guide plate issue? Need different rocker arms? Push rods? And info or suggestions would be great.
3Mike6
18
Jun 3, 2008 07:02 PM
Shelby Sam
Apr 10, 2004 01:10 PM
WOSOS
Aug 28, 2002 07:26 PM
TOUGHY17
Nov 6, 2001 10:27 PM
