Help, I screwed up big time
First time ever doing this. I installed the battery cables backwards. The starter relay arced out and the little brown ground wire melted the insulation. The truck has the wrong battery in it, came installed with the truck, and the poles are reversed. I had removed the battery to do other things. The battery has marine type clamps on it that covered up the markings on the battery.
Now, I have replaced the start relay and fixed the melted wire. I still am not getting any juice to anything, no lights. Completely dead. The battery is charged. I assume the fuzable link to the altinator is fried but would that cause a complete dead system? I inspected the wiring in the engine compartment and under the dash. No blown fuzes either. What am I missing? Thanks..
You have reversed-biased the alternator diodes and fried them. If you have "no juice" anywhere there must be an open wire, possibly the supply to the ignition switch.
You can also jump to the S terminal in the solenoid to see if it cranks. A connection may be burnt even though the wire checks out on the ohmmeter.
Your problem should not be hard to find. Fix and report back.
Doing what you did is very dangerous.
When I jumped the starter solenoid, the starter cranked. From the description stated in the Chilton manual, the fuzable link is toast. Now, to replace the link and go from there...
I have a 1972 Ford truck manual on CD. When I upgraded to windows 10, the file got corrupted and windows won't let me repair or reload the CD. Bummer...
Yes, that is good news and logical.
I have thought about your situation. I think the arc in the solenoid was from the S terminal back into the switch. Even though the switch was off there may have been an arc into the main power lead to blow the fusible link.
Anything that has transistors would be suspect- ignition modules, voltage regulator.
If I were you, I would replace the fusible link, regulator, alternator and ignition switch. And lift all connectors, check, sand, tighten. Not a whole lot of money but chasing down stuff piece-by-piece will cost you a weekend.
In a situation like yours involving hundreds of amps there are large voltage transients that can jump switches.
Go and sin no more. Please report back so we can add your experience to our knowledge base.
Semper Fi
Semper Fi
My ignition on this truck is points and condenser. No headlights either so it may be the ignition switch. I will hit the parts store in a bit.
As far as my CD manual goes, I could access it easily before loading windows 10. I also updated acrobat dc. When I bought this manual on cd, I thought I could just access the info from the disc. But no, I had to load it on the computer. I will try to uninstall it and start over. One of the flags I get is that I am not authorized to use the manual. Go figure..
All fixed. I replaced the fuzable link. Lights came on and the truck started. Alt gauge shows charging. I saw on another post when I searched fuzable link problems that if the linnk is blown, the truck is completely dead. That is what I had. I am going to pick up another link to keep in the tool box. The link I bought came with a splice and eyelet to install. Thanks for all the help you guys gave me. Now to get plates and drive it......
A few weeks ago I read that the early Windows 10s you will not be able to read CDs or watch DVDs but later versions you will. Windows 10 will be like Vista which was a royal pain in the butt, mostly with compatibility issues. I said forget that, I'll stick to my 7 and if this goes down, I have a refurbished one that is 7.
geoff69a1
07-24-2018 11:41 AM
86 4x4 ranger
08-08-2017 05:12 PM
nahtanfunk
04-15-2007 01:58 PM
broke77f100
03-28-2007 08:36 PM
Livsgrrl30
Electrical Systems/Wiring
28
06-09-2004 08:02 PM
