Help Hurry
Old Mar 28, 2007 | 08:13 PM
broke77f100's Avatar
broke77f100
Help Hurry
problem with my dads 86 F-150 300-I6 4 spd manual. no power to anythin at all? the battery was fine but we did have the doors open for like 1.5 hrs and i dont think that would matter cuz none of the interior lights worked before anyhow, what could it be? its not the starter solenoid either cuz we put a new one in. is there a possibility of some fuses fried? the headlights or starter or anything do not work not even the stereo
Old Mar 28, 2007 | 08:29 PM
Franklin2's Avatar
Franklin2
Go over to the starter relay. On the large post that hooks to the battery +, there should be smaller wire(s) that hook there too. This smaller wire powers the whole truck. Follow the wire and right at the end, or somewhere along it's path you will find a colored rubber thing. This is a fusible link. Pull on it, and check it to see if it's burnt. If you were doing some electrical work, and did not disconnect the battery, then that's probably what it is.
Old Mar 28, 2007 | 08:32 PM
broke77f100
well what do i do if its burnt
Old Mar 28, 2007 | 08:35 PM
Franklin2's Avatar
Franklin2
Go to the store and buy a new one, and splice it in the wire.
Old Mar 28, 2007 | 08:36 PM
broke77f100
oh ok thanks i wasnt sure
68 f250
19
Mar 27, 2012 07:27 AM
84 f250 6.9
59
Dec 28, 2009 08:52 AM
ultimatereality5
1997 - 2003 F150
Apr 27, 2007 09:10 PM
kopp16387
Dec 18, 2004 10:16 AM
Chevythunder7578
Feb 3, 2004 10:15 PM
