Speedometer inoperative
Old Aug 22, 2015 | 08:30 PM
loveless41908's Avatar
loveless41908
Verified cable and gauge good.
Plastic gear seems fine.
Any ideas?
Old Aug 22, 2015 | 08:54 PM
Franklin2's Avatar
Franklin2
There is a worm gear on the shaft of the transfer case or transmission. It must be missing or something is wrong with it.
Old Aug 29, 2015 | 05:37 PM
85_Blue's Avatar
85_Blue
Is your cable one piece or two? If two then definitely check the lower end by the tranny.
Mine broke there (after I removed the plastic gear, I noticed the broken cable) & I think the cruise control module seized on me.
Good luck Bro
Old Aug 30, 2015 | 08:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
TWO different speedometer gears:
Metal or nylon DRIVE gear on the output shaft / Nylon DRIVEN gear on the end of the cable.
Inside the speedometer cable housing is a woven steel core that's supposed to be lubed every so often. When the lube dries out, the core binds up inside the housing, eventually snaps.
Auto parts stores sell a universal woven steel core kit. Cut it to length, coat with a fine film of graphite, install in the housing.
ericconn
Jul 13, 2013 03:30 PM
billadas
May 9, 2013 12:31 PM
codycapek
Feb 19, 2013 02:03 PM
46069dord
Jan 24, 2008 05:18 PM
JRguy
Nov 23, 2004 02:43 AM
