Intermittent Code 41
Old Aug 22, 2015 | 04:31 PM
Jetmechkc135r's Avatar
Jetmechkc135r
Hello Folks,
I'm looking for some guidance before I change my injectors. A little about my rig:
93 F-350 XLT 7.5L
crew cab truck
188,000 miles
trouble I'm having is with an Intermittent Code 41 (Lean) only visible during the engine running test and does not store, and I have not noticeable issues with it running
I have changed the follow:
PCV valve
EGR valve
Oxygen sensors
Doe any one have any guidance for me?
Old Aug 22, 2015 | 04:58 PM
rla2005's Avatar
rla2005
You only have one oxygen sensor so I assume the above is a typo. Check your fuel pressure with the engine running at idle.
Old Aug 22, 2015 | 05:22 PM
Jetmechkc135r
Yea Sorry just one O2 sensor
Just got back from getting a new pressure gauge and it was 19 not running and 34 running and produced about 3oz in 30 seconds thru the bleeder port.
I did fail to mention it has new plugs, wires cap, and rotor.
What sound does a leaking injector make?
Old Aug 22, 2015 | 06:15 PM
timbersteel's Avatar
timbersteel
Vacuum leak.
Still have the original, brittle nylon vacuum lines? If so, start checking them.
Old Aug 22, 2015 | 06:17 PM
rla2005's Avatar
rla2005
Originally Posted by timbersteel
Vacuum leak.
I would lean more towards an exhaust leak.
Old Aug 22, 2015 | 06:49 PM
Jetmechkc135r
I did have them but I replaced most of them. I guess I may need to see if I missed one. I can also look for exhaust leaks . I feel, hear or sense no issues with drive ability that is why I was thinking a week injector. More to follow
Thanks Guys
latechbanjo
26
Nov 26, 2017 10:14 PM
Ddaybc
Oct 23, 2013 06:49 PM
camcam
Sep 28, 2013 06:41 PM
BURNSTOUGHFORD
Feb 22, 2011 01:12 PM
C Holmes
Jan 31, 2009 03:08 PM
