Door handle repair
Old Aug 20, 2015 | 09:53 PM
z_jriggs's Avatar
z_jriggs
Door handle repair
Working on my driver's side door handle. The push button seems to have excessive play (from overuse no doubt) and doesn't engage until the very end of travel. The passenger side is fine and engages much earlier. Is a new handle needed? Wanted to check with all to see if there is an easy fix out there. Thanks again!
Old Aug 21, 2015 | 06:02 AM
roadrash63's Avatar
roadrash63
Hey check the rod from the handle to the latch might need straitened
A flash light and mirror are needed.
Old Aug 21, 2015 | 12:16 PM
bcamill's Avatar
bcamill
Roadrash is right on checking the rod inside the door. I have found that these get fatigued and usually revert back to bending out of position. Good idea to replace, or if you weld. Weld a piece of steel along the rod. Leave room not to interfere with the ends. It will last your lifetime.
Old Aug 21, 2015 | 12:43 PM
ctubutis's Avatar
ctubutis
IIRC there are also some plastic bushings connecting some of the moving parts that can break; new ones are available from the HELP! section at various parts places.
Old Aug 21, 2015 | 09:54 PM
z_jriggs's Avatar
z_jriggs
Thanks for the information ya'll. I'm going to take a look this weekend and see what she looks like.
crazy96863
May 23, 2014 09:01 AM
emgee
Jun 4, 2013 05:49 PM
kingnine
Aerostar
Nov 21, 2006 10:02 PM
burrelld
Aerostar
Oct 22, 2003 06:53 PM
