Need help with door handle
Old Jun 4, 2013 | 11:24 AM
emgee's Avatar
emgee
Does anyone know how to re-attach the latch actuator rod to the door handle assembly. I disconnected the rod last year so I could remove the door latch and spray prime the exterior door. I have spent a lot of time trying to get the rod into the yellow plastic clip and can't figure out how it's done. There is very little space to work in with the window channel in the way. There is an access hole above the the connection point but it's too small for most tools. Is there a tool or trick to this?
[/URL][/URL]
Old Jun 4, 2013 | 11:57 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Believe it or not all you should need to do once the end of the rod is in the hole in the clip is push, the clip is designed for the assembly line so isn't supposed to require any tools to assemble.
Old Jun 4, 2013 | 03:50 PM
emgee's Avatar
emgee
Thanks. I was trying to do this INSIDE the door(duh). I figured it out...you attach the rod to the door handle on the OUTSIDE through the hole for the door handle and then push the assembly back into position and bolt it in place. Kind of like assembling the slider locks.
Old Jun 4, 2013 | 03:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
A picture is worth 1,000 words.
Old Jun 4, 2013 | 05:49 PM
emgee's Avatar
emgee
Thanks for the drawing, Bill.
THE BLUE HEAP
Mar 14, 2019 01:55 PM
Goofy1129
Jan 18, 2016 12:29 AM
kingnine
Aerostar
Nov 21, 2006 10:02 PM
burrelld
Aerostar
Oct 22, 2003 06:53 PM
