Can't Pull codes, other problems...
Old Aug 20, 2015 | 10:54 AM
JW1971's Avatar
JW1971
Cant Pull Codes
***Note: Cross posted in Bronco forum. - just trying to get as much info before I get some so i can work on it tonight***
1993 5.0 E4OD
Driving home tonight sitting at stop light about .5 mi from house started getting very rough idle, check engine light came on and engine died.
Put in park started back up Check Engine light is on.
Seemed very sluggish and just not running good. OD On/Off button will not work(light stays off) Nursed it home.
Tried to pull codes and CEL stays solid. Disconnect battery, then reconnect and try to pull code and self test starts but doesn't finish. I hear like a fast electrical short sound and CEL flickers. Then CEL stay solids.
Self test will not start again unless I disconnect battery. Rinse Repeat. Self test never gets going.
Darkness and Thunderstorms stopped my troubleshooting.
Does start and shift into drive and reverse.
OD on/off button does not work with, I was able to get a KEOR test to start and OD on/off button worked during that test.. No codes during this test....
Sigh. Sorry to Ramble.
Old Aug 20, 2015 | 11:41 AM
timbersteel's Avatar
timbersteel
Sounds like a failing PCM.
Just pull it and inspect the board.
Old Aug 20, 2015 | 12:40 PM
JW1971's Avatar
JW1971
Thanks timber. your the 2nd vote on that.
Old Aug 20, 2015 | 02:41 PM
dixie460's Avatar
dixie460
I'll chime in with the third vote for failing PCM.
Old Aug 20, 2015 | 03:56 PM
ZMax's Avatar
ZMax
Check/Swap the Fuel Rly with the EEC Rly...
Either the EEC will work and the Fuel pump won't OR the EEC will work and the Fuel pump WILL work or maybe that's just not the problem..
My EEC Rly was intermittent and caused your issue and MANY more....
Old Aug 20, 2015 | 06:09 PM
JW1971's Avatar
JW1971
Got computer out and opened it up..... Think we might have found the problem.
1993 Ford Bronco pictures, photos, videos, and sounds | SuperMotors.net
Then the T-storms started and had to stop. Couldn't get other computer in yet.
Will have to do tomorrow after work.
Old Aug 21, 2015 | 05:07 AM
ZMax's Avatar
ZMax
I would follow that circuit trace back to the connector to determine if there is a short somewhere (sensor,relay, etc) BEFORE you try the new EEC...
You may burn up the new EEC if you don't...
I had a burned trace too (I mag wired it) and it was not the problem..
ALSO... The connector on the EEC was not making solid contact.. I cleaned and applied connector grease which helped a good deal...
Old Aug 21, 2015 | 09:44 PM
JW1971's Avatar
JW1971
2nd computer put in, still same symptoms, was able to pull codes, 111 111 512 512
Checked all ground and all seem to be good.
The 2nd computer sat in my garage with case off for about 2 years, board looked okay when put back together.
So either other computer is bad also, or I got wiring issues to figure out.
Electrical troubleshooting is not my strongest thing, lol. How do I check for 12v on Pin 1? backprobe or pull PCM plug off and check at pin?
I did swap horn/eec relay and same results.
Old Aug 21, 2015 | 10:22 PM
F350 1990's Avatar
F350 1990
Pretty evident the swapped-in EEC isn't getting 12V as its memory (KAM) is losing history based on the codes.
The other board looks to have taken power, FP circuit hits, and overload hits across a number of areas --- unless you're an Intel 8XXX specialist, I'd pass on trying to salvage it as the board appears to be de-laminated under the capacitor and elsewhere.
Old Aug 23, 2015 | 06:40 AM
JW1971's Avatar
JW1971
I have checked I am getting 12v to Pin 1 on the Connector.
Think I need to get a "known good" PCM and put it in and see if its the computer.
All Fuses/Relays and grounds have been checked.....
Old Aug 24, 2015 | 05:06 PM
JW1971's Avatar
JW1971
UPDATE..... picked up remanufactured computer from NAPA..... Truck wouldnt start with it in.... i was able to pull codes on this one. Seemed like fuel pump wasnt priming with this computer. Making NAPA get me a new one....
But good sign with this computer that i am able to actually pull codes. Will see in a couple days when new computer is here..
PS: I put bad computer back in and it starts right up, Still cant pull codes on that one and it runs like crap. So I am still thinking PCM is the culprit.
Old Aug 24, 2015 | 07:18 PM
ZMax's Avatar
ZMax
Did you chase the burn't lands BACK to the connector and see what those pins are connected to???
The fact they were burn't is a real cause for concern.. IF you don't you might just burn the new EEC's up..
Just an FYI...
Old Aug 28, 2015 | 07:03 PM
JW1971's Avatar
JW1971
Update 2nd reman computer fixed problem. Unless there is some short i couldnt find, i think i am good to go
Old Aug 28, 2015 | 07:43 PM
rla2005's Avatar
rla2005
Good deal!
JW1971
1978 - 1996 Big Bronco
Aug 20, 2015 06:10 PM
jv2290
Jan 6, 2011 02:03 PM
snurchi
Sep 7, 2010 09:05 PM
aljen466
Electrical Systems/Wiring
Jan 20, 2009 11:02 AM
bbarnes
Sep 6, 2004 09:12 AM
