injecion pump and lines.
Old Aug 19, 2015 | 03:01 PM
charlie555's Avatar
charlie555
I have a 1985 f250 with a 6.9l diesel in it and I need to change a fitting and a line and would like to know if it is possible to inter change parts off of a 7.3 injection pump I think they are the same and I have to drive to go pick the parts up so I just would like to know if they are the same.
thanks.
Old Aug 19, 2015 | 03:40 PM
sjwelds's Avatar
sjwelds
Yes. They are the same. Now there are some minor differences from truck engines to van engines, but as far as 6.9 vs 7.3 AFAIK it's the same. Make sure you have a total of four anti-vibration line clamps attached to the cluster of lines.
JM2CW
Old Aug 19, 2015 | 07:05 PM
Runningaford's Avatar
Runningaford
thanks.
You need to go read the sticky "top dead center mark"; look for the post by FORDF250HDXLT
I just read through all of that yesterday; somewhere in there, it specifically states not to mix 6.9, and 7.3 injection lines. The way it read, you can swap 7.3 for 7.3, or 6.9 for 6.9, or swap entire set of lines of 6.9 to 7.3, or 7.3 to 6.9.
Apparently though, just swapping a single line will cause that cylinder to not fire properly; perhaps even knock a little. The reason for this is apparently the routing of lines=lengths are different between the two.
Old Aug 20, 2015 | 12:10 AM
Ford F834's Avatar
Ford F834
The 7.3 injector tips were positioned ever so slightly higher within the cylinder head for emissions reasons, and the hard lines were therefore a very tiny bit longer. As I understand it you can interchange 6.9 and 7.3 lines but only as a set, otherwise the the one cylinder will have a different ignition timing and it will not run right. 7.3 pick up trucks had the timing adapter on cyl #1, vans had the adapter on cyl. #4, but they are otherwise the same and are interchangeable.
Old Aug 20, 2015 | 12:41 AM
Runningaford
I had no idea it was for emissions. If so, then would that lean towards indicating you'd get a slight bit more of horsepower out of a 7.3, running a complete set of 6.9 lines?
Old Aug 20, 2015 | 02:11 AM
Ford F834's Avatar
Ford F834
The difference would be in the heads. The line length just compensates for the nozzle position. The only thing running 6.9 lines on a 7.3 would do is create a tiny shift in timing. Not enough to notice unless it is just one cylinder firing at a slightly different time, making the engine run rough, similar to unequal injector pop pressures.
Old Aug 20, 2015 | 03:49 PM
charlie555's Avatar
charlie555
ok so will it work if I put a full set of 7.3 lines on my 6.9? and is the injection pump the same on the 7.3 and 6.9?
Old Aug 21, 2015 | 02:49 PM
Ford F834's Avatar
Ford F834
As long as the whole set is switched you should be fine. There are differences in the injection pump as well, but they interchange. 7.3's are capable of delivering slightly more fuel, so depending on how it is calibrated you might need to turn the fuel screw down a tad (if you get black sooty smoke).
Old Aug 22, 2015 | 04:53 AM
Dieselamour's Avatar
Dieselamour
JM2CW
Second the comment to use all four line clamps. Make sure the clamps and the lines do not touch by positioning the rubber dampers correctly. I did not replace all of mine and ended up stranded, performing field surgery, , on the capital beltway.
87F250onFUELS
Jul 1, 2017 05:06 PM
genscripter
May 2, 2017 05:26 PM
adamkat22
Dec 28, 2016 01:07 AM
chucky0094
General Diesel Discussion
Oct 9, 2007 07:49 AM
vintage super duty
Mar 24, 2007 11:40 PM
