oil pressure
Old Aug 19, 2015 | 01:53 PM
shermy452's Avatar
shermy452
oil pressure
Hey, i was wondering everyone's oil pressure. Mine's reading on the higher side of the "a" of normal section, obviously when i'm on highway. I realize it get's high, but how high is everyone's getting?
Old Aug 19, 2015 | 02:24 PM
HIO Silver's Avatar
HIO Silver
Just like the temperature and fuel gauges, circuit resistance + age will vary from truck to truck.
Old Aug 19, 2015 | 02:35 PM
shermy452's Avatar
shermy452
i just didn't know if there was a concern with where i'm at?
Old Aug 19, 2015 | 07:49 PM
Blue and White's Avatar
Blue and White
Like HIO said, hard to tell if it is really too high with the stock gauge. An aftermarket mechanical gauge can tell you with good accuracy. If you are worried, suggest you install one at least temporarily as a diagnostic. The low cost parts store mechanical type work fine. 50-60 psi would be about normal for a healthy engine on the highway. Over 70 psi would be unusual and maybe cause for concern.
Old Aug 20, 2015 | 02:13 PM
Ozzie H.'s Avatar
Ozzie H.
You'll get variations with engine temperature, speed, & wear, and oil viscosity, but your description sounds similar to mine. If concerned, as suggested, add a calibrated gauge and compare to the engine's specs.
stuart olson
24
Apr 22, 2019 06:34 AM
sunogbahay
Jun 7, 2016 09:45 AM
cheese70
Mar 16, 2009 07:46 PM
donniezyea
Apr 19, 2006 10:15 PM
Skagit
Oct 17, 2003 08:39 AM
