Rear differential
Old Aug 19, 2015 | 10:27 AM
waldreps's Avatar
waldreps
Rear differential
I got a new to me truck. It's a 2004 F150 Lariat 4x4 with the 5.4L. It's got a whine that I believe is coming from the rear differential. I'm going to change the fluid to see if that helps any. My axle code is 26 which I believe is 3.73 non-limited slip. My owners manual says to use 75w-90 but I've seen a lot of posts on here that say to use 75w-140. Which is right or better? Also, is my rear differential the 9.75"? Thanks.
Old Aug 19, 2015 | 11:36 AM
bbender85's Avatar
bbender85
75w-140 is due to the limited slip. (EDIT: as to not spew bad info, it offers more protection on the high temperature end, and clutch limited slips generate extra heat. unless you're towing heavy and/or really beating on it i wouldn't bother with the 140 weight especially in an open diff.)
can you describe your whine? is it only under load/go away when off the throttle?
Old Aug 19, 2015 | 12:09 PM
waldreps's Avatar
waldreps
So, I should stick with 75w-90 then in a non-limited slip? Yes, the whine is only under load starting at about 40mph and will stop when I let off the throttle. That's probably the rear differential right?
Old Aug 19, 2015 | 12:34 PM
bbender85's Avatar
bbender85
edited my post above.
i have a driveline whine with the exact same symptoms. i've only owned the truck since november, and one of the first things i did last fall was change the rear diff fluid (went with 75w-140, 3.73 LS rear end), and if anything it has gotten louder. i've done a little reading and it sounds like it's not uncommon on these trucks. curious to see what other answers you get.
Old Aug 19, 2015 | 02:35 PM
waldreps's Avatar
waldreps
Thanks Brandon. I think a differential whine is usually a symptom of it's initial setup but I figured a fluid change wouldn't hurt. I hope someone else chimes in on whether it's best to use 75w-90 or 75w-140 in a non-limited slip diff.
Old Aug 19, 2015 | 03:39 PM
1saxman's Avatar
1saxman
Considering the climate in your area, the 140 would not be something I would use. I would stick with the recommendation in the manual. Heck, you might find out it's tire noise.
Old Aug 19, 2015 | 04:15 PM
waldreps's Avatar
waldreps
I didn't think about the cold weather. That's a good point. I probably should just stay with the 75w-90. The all terrain tires do make some noise but the whining noise will stop when I let off the throttle.
Old Aug 19, 2015 | 04:55 PM
1saxman's Avatar
1saxman
That pretty well points to the rear alright. I guess it depends on how loud it gets and how much it bothers you. I noticed today I have a very slight whine on my truck with only 19,500 miles, and it does the same - stops when you let off the gas. I had a Jeep Cherokee that did that for the whole 90,000 miles I had it. Sometimes I think we're listening too hard for noises.
Old Aug 20, 2015 | 05:11 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Interesting thread right here: Ford 9.75" 75w90 | ATF, Differential, Trans, Brakes, P/S | Bob Is The Oil Guy
Old Aug 20, 2015 | 06:50 AM
bbender85's Avatar
bbender85
this holds truth in my case; i paid more than i wanted to for my truck, so everything working less than optimal gives me anxiety haha.
that said, and back to the subject, i wonder about the pinion bearing.
Old Aug 20, 2015 | 09:57 AM
waldreps's Avatar
waldreps
After Tim's post, I did a little more research. See the links below:
2004 F150 Rear Diff fluid [Archive] - FSB Forums
Help with correct differential fluid selection... - Page 2 - F150online Forums
Ford is saying to change the 75w-90 recommendation to 75w-140. It seems that they're usually talking about the limited slip rear but one of the Ford notes makes it sound like all vehicles should use 75w-140 now instead of the 75w-90. They even say to change the tag on the rear diff. They don't really make a distinction about climate so I think I'm going to go with full synthetic 75w-140. It probably won't stop the whine but at least it will be fresh fluid and have what Ford now recommends.
Old Aug 20, 2015 | 02:22 PM
1saxman's Avatar
1saxman
Let us know how it works out.
Old Aug 20, 2015 | 08:59 PM
steve(ill)'s Avatar
steve(ill)
on your noise, I had a 2001 with the 9.75 axle and 3.55 gears. Changed the lube every 50K miles... still had the pinion bearing go out about 200K miles... I bought a kit and did the ring gear bearings also to make it like new........... used original clutch (LS) and gears.
Old Aug 23, 2015 | 09:03 AM
Feedguy's Avatar
Feedguy
2004 F150 rearend whine
Same story on mine. 103500 miles or so currently. Been whining since I bought it four years ago @ 72000 miles. Just under load. Coasting it gets quiet. Changed the fluid etc. No difference. Had a mechanic tell me 20,000 miles ago the rearend was shot. He might have been wrong? 3.73 with LS. Gonna run it, see what happens.
Old Aug 23, 2015 | 10:34 AM
waldreps's Avatar
waldreps
I crawled under mine the other day and saw the new tag on it saying to use only 75w-140 indicating to me that it has already been in for service at some point and had the new recommendation fluid put in. I think I'm going to leave it alone for now.
Texas Bob
Oct 19, 2019 12:12 AM
TxBoi84
2009 - 2014 F150
Jun 7, 2018 07:05 PM
Kijutsu
2004 - 2008 F150
25
Feb 21, 2011 09:46 PM
Midnightride42
1997 - 2003 F150
Jul 31, 2009 10:36 AM
tow4show
Nov 15, 2006 02:04 PM
