Extra Space try#2
Old Aug 18, 2015 | 03:33 PM
waituntilthebeep's Avatar
waituntilthebeep
Extra Space try#2
I posted earlier but something went wrong with it so let's try it again.
I wanted to add on some extra battery banks for my trailer to tap into for extended stay off the path so to speak. I hate the mega sized, 50 to an acre, RV parks and prefer to find a nice quiet place and keep it that way by not running a generator. I took the spare tire storage compartment that my 74 SCS has and turned it into an add-on space. Put 2 Group 29 deep cycles, an isolator relay and the 7 wire junction box in there. Have other ideas for stuff to go in the space but have not ventured down that rabbit hole yet.
Ford Truck Picture by waituntilthebeep | 4077464 | Ford-Trucks.com
Ford Truck Picture by waituntilthebeep | 4077465 | Ford-Trucks.com
Next step is to remove the 1G alternator and put in a much heavier 175 amp pad mount alternator from a heavy truck application. Already figured out how to set it up and use the existing pulley set to drive a dual belt. That should put the wattage in the cottage and keep all the batts charged. Will post pics of that when I get it built.
Old Aug 18, 2015 | 05:57 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Nice set up.
Old Aug 18, 2015 | 06:41 PM
Thunder:Raven's Avatar
Thunder:Raven
Nice job. Are you working in the electric industry?
Old Aug 18, 2015 | 08:41 PM
waituntilthebeep
No, but I am a big rig mechanic and I do lots of upfit and retrofits on all sorts of equipment. I drastically overbuild everything. This truck will be not be an exception to that rule.
Old Aug 19, 2015 | 01:24 PM
Thunder:Raven
I should have known when you said pad mounted.
So let's see the camper...
Old Aug 24, 2015 | 09:52 AM
waituntilthebeep
https://www.ford-trucks.com/g/picture/4098874
That's the beasty...
waituntilthebeep
Aug 18, 2015 10:12 AM
JR2980
Jul 24, 2014 02:25 PM
chetspencer
Mar 14, 2014 08:24 PM
jackstraw
22
Jan 3, 2012 07:53 PM
ford_man
Jan 29, 2007 10:04 AM
