95 f350 psd no start no smoke no tach known GOOD cps
Old 08-18-2015, 11:46 AM
fnfast88's Avatar
fnfast88
fnfast88 is offline
I went to lunch/dinner at work last night walked into subway got food came out no start. I had a new cps that I verified good on this truck kwhen I bought it from parts house) in the glove box. Switched to backup idm checked all the maxi fuses. Pcm?
Mind you it was 430 am when I got to it after work.
Old 08-18-2015, 11:49 AM
cowmilker08's Avatar
cowmilker08
cowmilker08 is offline
The parts house CPS might have gone bad in the mean time. Buy a Ford or IH CPS, otherwise start inspecting the wiring to the CPS.
Do you get a WTS light?
Old 08-18-2015, 11:53 AM
fnfast88's Avatar
fnfast88
fnfast88 is offline
Wts is good and normal operation
With the cps just sitting in the glove box I couldn't see it going out. I could grab one off of my parts truck and see if that fixes it. I kinda scanned the cps wires the connection looks solid and clean.
Old 08-18-2015, 11:59 AM
fnfast88's Avatar
fnfast88
fnfast88 is offline
It's just weird that it ran great all day. Not even a stumble out of it. I will check the cps wires all the way up. I have to say I have already repaired the fuel bowl harness and deleted the fuel heater rerouted the harness so it does not rub the fuel bowl
madMatador78's Avatar
madMatador78
madMatador78 is offline
Try unplugging ICP (Front corner drivers side head, 3 wires) and see what happens.
Old 08-18-2015, 12:02 PM
fnfast88's Avatar
fnfast88
fnfast88 is offline
Ok I won't get to it until 4am
Old 08-18-2015, 12:14 PM
cowmilker08
Do you get a CEL?
Also, review this link: https://docs.google.com/file/d/0Byb4...VGc/edit?pli=1
Old 08-18-2015, 12:29 PM
fnfast88's Avatar
fnfast88
fnfast88 is offline
Cel is on but I belive it's supposed to be on koeo
Old 08-18-2015, 12:38 PM
cowmilker08
No, not until you leave the key on for an extended time period. Then it will come on.
Old 08-18-2015, 12:43 PM
fnfast88's Avatar
fnfast88
fnfast88 is offline
Then yes I have a cel
What scanner do I need to get
Old 08-18-2015, 12:49 PM
cowmilker08
A good one. Cheapo parts store scanners won't work.
AE, SnapOn MT2500, etc.
There is also Torque Pro, but its not for the faint of heart.
Old 08-18-2015, 01:14 PM
rusty1161's Avatar
rusty1161
rusty1161 is offline
Check your IPR. If the nut fell off, the solenoid will too. Also check the IPR connector/harness. The split loom hides damage to the wires from years of oil and fuel leaks that eat away the insulation and results in a short.
Rusty
Old 08-18-2015, 10:12 PM
Action4478's Avatar
Action4478
Action4478 is offline
If the CEL is on KOEO , is it faint ? If so you need a PCM . Is the truck chipped ?
Old 08-19-2015, 04:03 AM
fnfast88's Avatar
fnfast88
fnfast88 is offline
Ipr new 8 months ago
Old 08-19-2015, 04:30 AM
fnfast88's Avatar
fnfast88
fnfast88 is offline
Revision:
CEL on only while cranking.
I gotta few bulbs out but still no cel without cranking.
Quick Reply: 95 f350 psd no start no smoke no tach known GOOD cps
