Change Oil Indicator
Old Aug 18, 2015 | 10:18 AM
CollinsCD's Avatar
CollinsCD
I posted this on the Super Duty forum with no responses so I thought I would try here.
My oil indicator is coming on for an oil change even though I only put 1800 miles since since last change. Now this change was in February and I did reset the indicator after that oil change.
Why would the indicator tell me my oil is due for a change even though it only has 1800 miles on the oil? Does it also take into consideration the amount of time on the oil? As you can see I'm only putting on 300 miles or so a month.
This is the second oil change I've done since owning the truck and it also did the exact same thing after the first change.
__________________
Old Aug 18, 2015 | 12:10 PM
CollinsCD's Avatar
CollinsCD
Getting some responses now on the SD forum. Might be that Ford has a 6 month default time limit regardless of miles.
wfedwar
Aug 10, 2017 07:30 PM
CollinsCD
Aug 19, 2015 09:17 AM
KPT
6.7L Power Stroke Diesel
Jun 13, 2013 07:27 AM
nut1605
Nov 27, 2011 10:15 AM
White Knight 2011
Sep 11, 2010 03:44 PM
