96 ford powerstroke
Old Aug 18, 2015 | 09:37 PM
Action4478's Avatar
Action4478
The FPR screen is on the side of the fuel bowl attached to the FPR . It is used to remove the Air from the fuel system as the fuel returns to the tank . Your fuel pressure will read low if it is plugged . Clean it & retest . The fuel pressure readings are based on the pressure as the fuel returns to the tank .
Old Aug 21, 2015 | 06:21 PM
Kugo's Avatar
Kugo
Ok changed the cps got two new batteries. Still little to no power.
Old Aug 21, 2015 | 06:37 PM
Action4478's Avatar
Action4478
THe next cheap test should be the ICP sensor on the driver side head ( next to the lifting ring ) . Its a 3 wire sensor . Un plug the connector & look to see if there is oil on it . If it is oily, replace the sensor . You can also run temporarily with it unpluged for a test .
Old Aug 21, 2015 | 10:17 PM
Kugo's Avatar
Kugo
We already replaced that two weeks ago.
Old Aug 21, 2015 | 10:57 PM
Action4478's Avatar
Action4478
I re read , I see that was in the first post sorry . 1280 relates to the HP oil pressure . If you can , we need to see some real time data. ICP , IPR dc .
Old Aug 21, 2015 | 11:02 PM
Kugo's Avatar
Kugo
Any other ideas
Old Aug 21, 2015 | 11:03 PM
Kugo's Avatar
Kugo
It is also not pulling any codes
Old Aug 22, 2015 | 07:47 AM
F350-6's Avatar
F350-6
Did you ever check the fuel pressure? What does it read?
Before and after cleaning the screen.
miketaylor
2009 - 2014 F150
Apr 4, 2017 09:19 AM
ramsay
Jan 16, 2016 10:01 PM
chritter
Aug 23, 2012 04:47 PM
MX_Fyrcaptain
Mar 24, 2012 06:50 PM
DixieDirt
Oct 19, 2007 08:32 PM
