63 Econoline Front Hub
Old Aug 17, 2015 | 06:09 PM
longagostephen's Avatar
longagostephen
The front hub on my 63 Econoline has a significant amount of wear within the hub. The bearing race has 1/16th inch of play when seated in the hub (I just replaced the bearings). The easiest approach would seem to be replacing the hub, however I cannot locate one anywhere.
Does anyone know how I can get my hands on a 63 econline front hub?
Is the Econoline spindle compatible with any other Ford vehicles?
Finally does anyone have any experience with getting a hub machined and locating over sized bushings?
Thanks!
The hub PN I need should be C1UU 1102-A
Old Aug 18, 2015 | 09:28 PM
EmilBarnabas's Avatar
EmilBarnabas
The front hub/drum is Raybestos 2648R. Rock Auto has it for $53.75. This is the finned version for extra drum cooling, but will work on all 1961-1967 Econolines.
Econoline Front Axles
Old Aug 18, 2015 | 11:33 PM
longagostephen
The Raybestos 2648R is just the drum and RockAuto does not sell the hub. The drum I have is fine, its the hub with the problems.
I cannot find anyplace that sells a hub.
Old Aug 19, 2015 | 09:28 PM
EmilBarnabas
Sorry, I thought that was the number for the hub and drum combo.
There is one for sale on eBay.
http://www.ebay.com/itm/like/181732473162?ul_noapp=true&chn=ps&lpid=82
Try Vic: vlafountaine (at) socal.rr.com
If he has any used ones, he will be honest enough to sell you a decent one. He hangs out on the VintAGE-Vans discussion boards.
I just found that Collectors Auto Supply in Washington has 22 of the C1UU 1102-A in stock. They are not listed on the website, so shoot them an email.
CollectorsAutoSupply.com
Old Sep 5, 2015 | 07:57 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks!
FoMoCo: Hub only furnished with the brake drum.
C1UU-1102-A .. Hub & Drum Assy-Use with 10" x 2.50" brakes / Obsolete
1961/67 E100 / No Ford dealer or obsolete parts vendor has any.
queen of spades
Mar 22, 2015 04:38 PM
cotote
Dec 7, 2008 06:23 PM
cochran226
Dec 22, 2007 03:39 PM
dahunt
Mar 27, 2007 03:02 PM
Rockwell
Feb 18, 2003 07:15 PM
