Sponsored by: Real Truck
Drag link adjuster
Old Aug 17, 2015 | 03:06 PM
VAfordsuperduty's Avatar
VAfordsuperduty
Drag link adjuster
hey guys I am attempting to replace my drag link bar because the tie rod portion on the passenger side is bad. The problem i am having is that I can't( or better put don't know how to) remove the drag link bar from from the adjuster. please help!
Old Aug 20, 2015 | 09:14 AM
f250mtnbikr's Avatar
f250mtnbikr
What year is your truck?
Is it 2 or 4 wheel drive?
Old Aug 20, 2015 | 10:38 AM
Greenscobie86's Avatar
Greenscobie86
You should loosen the collar and then it will simply unscrew from said collar. Depending on how rusty it is you may need some PB blaster and channel locks to get it to move.
Old Aug 20, 2015 | 05:21 PM
fishbones182's Avatar
fishbones182
Drag link adjuster
If the pb blaster don't do the trick hit it with a torch to warm it up a bit
Old Aug 20, 2015 | 09:01 PM
eberlestock's Avatar
eberlestock
I just did mine. After I got it off the pitman arm I supported it up with a tie down. Lots of penetrant and a butane torch got it moving after I loosened both lock bolts on the collar adjuster. Use a pipe wrench to turn it. A tip is to not jack up your wheels. Screw the new draglink in till it fits back in the pitman arm. This sets the length about the same. A couple turns on the collar should get your steering wheel straight.
Snuggyworm
May 6, 2012 11:08 PM
Snuggyworm
May 3, 2012 08:32 AM
quaallen
Offroad & 4x4
13
Feb 23, 2011 02:18 PM
Americanmadeford
Nov 1, 2007 07:39 PM
