Front passenger tire
Old Aug 16, 2015 | 10:25 PM
bizzelj's Avatar
bizzelj
Hey guys I recently bought new fabteck shocks new sway bar links and new 37in toto all terrain tires. I'm having a slight problem and want to get it fixed before it becomes an issue. My passenger tire is wearing faster than the rest any ideas on what would cause this?
Old Aug 16, 2015 | 11:17 PM
99powerstrokedF250's Avatar
99powerstrokedF250
How recently did you put them on? If it's been less than a few weeks and you can visibly see the wear, you've got a pretty bad alignment issue that needs to be addressed.
Old Aug 17, 2015 | 05:52 AM
bizzelj's Avatar
bizzelj
I put them on in May. I can see wear it's not bad but worse then the rest
Old Aug 17, 2015 | 07:42 AM
87crewdually's Avatar
87crewdually
Check ball joints, especially lower ones by jacking it off the ground and then pry it up to see if there's movement. Also check hub bearing. While your at it check tie rod ends.
Old Aug 17, 2015 | 07:43 AM
Ono6.0's Avatar
Ono6.0
Make sure you get the alignment checked. There is a way to set toe and the steering wheel, so the wheel can be straight but the tires could be wearing. Toe will eat tires fast if it's off
Old Aug 17, 2015 | 08:26 AM
bizzelj's Avatar
bizzelj
Thanks for the replies guys going to get it checked
Codelizard
Oct 21, 2016 09:46 PM
jasonodsky
Aug 22, 2011 09:51 PM
tboy
Nov 17, 2010 06:49 PM
WorkhorseF250
Jul 3, 2010 07:56 PM
ijaraptor
Sep 19, 2007 02:48 PM
