Warrentee plate decode
Old Aug 15, 2015 | 11:46 AM
john jamieson's Avatar
john jamieson
A trustee is selling an F250 down the street. The Plate reads as follows:
F250 CR554807
128 N F 250 E 81 F 24
7500 135 3800 71
My neighbor took a drive in it about a year ago and it ran well then, but won't start now. A quick look at it shows that it has an 8 cyl and a floor shift transmission. Also looks to have factory ac in it. It has its dents and wear but no rot or even any rust that can't be treated with rustoleum so I may have to make an offer on it.
Thanks for any info.
john
Old Aug 15, 2015 | 02:24 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Warranty Plate decode
Originally Posted by john jamieson
A trustee is selling an F250 down the street. The Warranty Plate reads as follows:
Warranty Number: F25CR554807 / WB: 128 / COLOR: N / MODEL: F250 / BODY: E81 / TRANS: F / AXLE: 24 / MAX GVW LBS: 7500 / CERT NET HP: 135 / RPM: 3800 / DSO: 71
F25 = F250 2WD
C = 292 2V
R = San Jose CA Assembly Plant.
554807 = 1064, assembled June 1964.
128" Wheelbase.
N = No such COLOR code.
F250 2WD .. 7,500 lbs. GVWR
E81: E = Red Crush Vinyl & Red Check Stripe Woven Plastic // 81 = 81B Custom Cab.
F = Borg-Warner T-98 4 Speed Manual Transmission.
24 = Spicer/Dana 60 Rear Axle / 4.56-1 / 5,200 lbs. Rear Axle Capacity.
7,500 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Aug 15, 2015 | 04:47 PM
john jamieson
Thank you.
john
Keith B
Apr 18, 2016 12:49 PM
cykoklr
May 30, 2015 04:19 AM
TheV8tractor
Feb 13, 2015 09:32 PM
Jfitzgerald
19
Nov 9, 2014 05:52 PM
rusbukt
Jun 30, 2014 07:13 PM
