Help Numberdummy!!
Old Nov 6, 2014 | 10:41 AM
Jfitzgerald's Avatar
Jfitzgerald
Help Numberdummy!!
Hi, new here. Second thread but love reading everything and am somewhere in the mid hundreds of the over 1000 pages! I have 2 66 f250s (I was told) and would love to know for sure if you would be so kind to help. The bottom truck numbers have me confused especially. Sorry for the lack of pics but I haven't figured it out yet. info is:
F25YR817575
129 BV F250 C81 A 24
07500 172 4000 73
F25BK891001
129 M F253(?) 481 F 24
06000 150 3600 73
Thanks,
John
Old Nov 6, 2014 | 02:28 PM
TA455HO's Avatar
TA455HO
Lead Gopher
This will be interesting. From what I know the sequence numbers for both trucks puts them in 1966 (732,001 thru 914,000), but the F253 doesn't show as a valid model code until 1967. I know those tags are very small so some have mistyped or misread some of the info on them before. Are you certain about the info? If so, ND to the rescue. Lol.
Old Nov 6, 2014 | 03:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Jfitzgerald
F25YR817575 / WB: 129 / COLOR: BV / MODEL: F250 / BODY: C81 / TRANS: A / AXLE: 24 / MAX GVW LBS: 07500 / CERT NET HP: 172 / RPM: 4000 / DSO: 73
F25 = F250 2WD
Y = 352 2V
R = San Jose CA Assembly Plant.
817575 = 1966, assembled February 1966.
129" Wheelbase.
BV: B = Caribbean Turquoise / V = (not listed for 1966).
F250 2WD, 7,500 lbs. GVWR
C81: C = Medium Green Crush Vinyl & Medium Green Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
24 = Dana 60 Rear Axle / 4.10-1 / No Limited Slip / 5,200 lbs. Rear Axle Capacity.
7,500 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
73 = Salt Lake City UT Ford District Sales Office, where the original selling dealer ordered the truck from.
F25BK891001 / WB: 129 / COLOR: M / MODEL: F253 / BODY: 481 / TRANS: F / AXLE: 24 / MAX GVW LBS: 06000 / CERT NET HP: 150 / RPM: 3600 / DSO: 73
F25 = F250 2WD
B = 300 1V I-6.
K = Kansas City MO Assembly Plant.
891001 = 1966, assembled July 1966.
129" Wheelbase.
M = Wimbledon White.
F253 = F250 2WD, 6,000 lbs. GVWR
481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
F = Borg Warner T-18 4 Speed Manual Transmission.
6,000 lbs. Gross Vehicle Weight Rating.
150 net HP @ 3,600 RPM
Old Nov 6, 2014 | 03:08 PM
Jfitzgerald
Thank you, thank you!! That helps a bunch and clears up things for me. I am selling the one with the 300 i6 and wanted to make sure I new what I was selling. Hoping to use the proceeds to finish the 352 rebuild in the other one. Really big thanks
Old Nov 6, 2014 | 04:16 PM
Jfitzgerald
Interestingly, the truck that is painted Caribbean turquoise is two-tone the other tone probably the V, is a cream color. But underneath the cream color you can see the Caribbean turquoise in wear spots which I thought was strange. The paint job looks very clean though and of the same timeframe as the Caribbean turquoise so I'm not sure what that's all about
Old Nov 6, 2014 | 05:15 PM
NumberDummy
I have the 1966 FoMoCo color chip chart that was used at the parts counter. It has chips of the actual colors glued to it, decodes all 1966 FoMoCo COLOR codes.
There is no V code for any 1966 truck, Bronco or Econoline.
V = 1966 FoMoCo Passenger Cars: Emberglo Metallic which resembles burnt copper.
Caribbean Turquoise was tu-toned with white, could be: C = Pure White / M = Wimbledon White
Old Nov 6, 2014 | 05:51 PM
Jfitzgerald
Here is the V, it looks like to me
Old Nov 6, 2014 | 05:55 PM
Jfitzgerald
And here is the truck.
Old Nov 6, 2014 | 06:48 PM
tbm3fan's Avatar
tbm3fan
No, it looks like an M as I can see the legs extending down into the black.
Old Nov 6, 2014 | 06:59 PM
Jfitzgerald
Embarrassing. I couldn't see the forest for the trees!! I see it now plain as day. Thanks everyone. Would they have painted over the green with the white to get the two-tone?
Old Nov 6, 2014 | 07:10 PM
NumberDummy
Originally Posted by Mr. Magoo
Here is the V, it looks like that to me.
It might look like a V to myopic Mr. Magoo, but it's not...it's an M
BM: B = Caribbean Turquoise / M = Wimbledon White.
Old Nov 6, 2014 | 07:38 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Yes. My tu-tone truck is gold under the areas that were painted white. Same deal.
Old Nov 7, 2014 | 11:48 AM
66f100project's Avatar
66f100project
This is great as shows the value of pics. As soon as I zoomed in on the V, I saw the M.
Old Nov 7, 2014 | 12:39 PM
Jfitzgerald
Me too! But it took someone else zooming and a post here!
Old Nov 7, 2014 | 12:53 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I'm still curious about the 253 for the Model Code. Here's what the MPC says on page 45 of text manual. Maybe we'll never know....
Name:  Model codes.jpg
