ball joints
Old Aug 15, 2015 | 10:23 AM
tanman722001's Avatar
tanman722001
ball joints
How hard is it to put upper and lower ball joints in a 97 f350 crew cab 2wd? Thanks
Old Aug 15, 2015 | 11:54 AM
'89F2urd's Avatar
'89F2urd
they can be a wh0re because they get stuck in there pretty good...all depends on when they were done last.
need a big ball joint press, once you put copious amounts of pressure on the ball joint via the press, give the ball joint housing (the chunk of metal attached to the axle that the ball joint is pressed into) some wacks with a big hammer to give em a nice shock load and they'll pop right out.
Old Aug 15, 2015 | 01:00 PM
GuitarJesus's Avatar
GuitarJesus
What he said. And I'm not sure if the ones you can borrow from Ho'Reillys or VatoZone will work. They don't have the attachments needed for a one ton truck, at least the ones by me.
Old Aug 16, 2015 | 09:06 AM
tanman722001
OK will have to do some checking on the tool. Thanks guys
Old Aug 16, 2015 | 09:17 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
2wd wont be bad.you'll get 'er.i recommend replacing with MOOG parts.
LSO1123
Sep 28, 2011 10:03 AM
F-250beast
Dec 29, 2007 06:10 PM
handsomerob
Sep 13, 2007 06:23 PM
wls
Jul 15, 2006 08:25 PM
joel frandsen
Bronco II
Jul 9, 2004 06:27 PM
