Instrument gauge proplem
Old Aug 13, 2015 | 07:44 PM
john jamieson's Avatar
john jamieson
I recently recently replaced my turn signal wiring in my column and in doing so pinched a wire that caused the turn signal and flasher fuses to blow. I fixed the short and replaced the fuses and the turn signals work fine. Now the fuel, oil, and temp gauges are pegging high. They worked fine before I touched anything. The manual I have says they are powered by a constant voltage regulator. What does it look like and where is it located? Anything else I should be checking? The truck is a '66 F-100, 240ci, three on the tree.
Thanks. john
Old Aug 13, 2015 | 08:25 PM
scottlathrop's Avatar
scottlathrop
The CVR is found on the backside of the instrument cluster. I've attached a picture of the approx. 1 1/2" x 1/2". wires attached send in 12 volts and come out approx. 5 volts to run gauges. Somewhere on the forum, there is instruction to build your own with parts from radio shack for about $8. That's the unit just above with long wires.
I'm not the expert here but a symptom of pegging gauges is the CVR is no longer working and the full 12 volts are going to the gage.
Old Aug 14, 2015 | 12:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
B9MZ-10804-C .. ICVR - Instrument Cluster Voltage Regulator (Motorcraft GR-508) / Obsolete - Available NOS & from auto parts stores.
Misc. applications: 1961/66 F100/1100 // 1960/65 Falcon / 1960/66 Thunderbird / 1962/65 Fairlane / 1965/66 Mustang / 1966/77 Bronco.
Old Aug 14, 2015 | 12:58 PM
daveengelson's Avatar
daveengelson
Posting pic from 65 Ford F100-F750 wiring manual. May want to pick up a copy, around 8 pages costing around $7. Most Ford part supplier's carry them or purchased from source; Jim Osborn Reproductions.
Should be able to enlarge slightly by clicking on the diag?
http://i300.photobucket.com/albums/n...1.jpg~original
Old Aug 14, 2015 | 09:35 PM
john jamieson
Thanks to everyone for your help. It seems like I fix one thing and break another.LOL
Becky_is_a_66
15
Oct 29, 2015 07:07 PM
riggerparish
Dec 21, 2013 02:14 PM
SwampyBull
Nov 1, 2012 09:14 AM
westtex
Jun 18, 2012 03:49 PM
Lou1967
May 28, 2009 12:13 AM
