6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Replacing broken DPF studs
Old Aug 11, 2015 | 11:36 PM
OpenTrackRacer's Avatar
OpenTrackRacer
I need to pull my DPF and as expected, the nuts are not coming off easy. I've been nailing them with liquid wrench and some local heat but they're really stuck. I got one moving with a breaker bar but the stud snapped a half a turn later.
Does anyone know if the studs are available and if so what the part number is??
Thanks!
Old Aug 14, 2015 | 09:32 PM
fatboytx's Avatar
fatboytx
I live in Texas and the underside of my truck looks new. I've had my DPF out and I don't recall studs but then I didn't look close because it just kinda came right out but I pulled up microfiche and it shows studs but no part number. Dunno ... maybe walk up to the parts counter and ask for help because it doesn't look like you can order a DPF stud online.
Old Aug 15, 2015 | 10:23 AM
73fan's Avatar
73fan
I would think you should be able to hammer or drill the old bolt out and just put in a standard bolt and nut.
cal74
1997 - 2003 F150
Jun 6, 2010 04:44 PM
dbuck50
Nov 21, 2007 05:27 AM
wildstang
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 19, 2006 09:10 PM
darkman
Aug 8, 2003 10:30 PM
erikl85
Garage & Workshop
Jun 14, 2003 12:22 AM
