Sponsored by: Innova
Remote Turn On
Old Aug 1, 2003 | 03:29 PM
acerockola77's Avatar
acerockola77
Remote Turn On
Can I just hook up the remote turn on to a positive feed so I can turn it on and off manually with a switch?
Old Aug 1, 2003 | 06:29 PM
superswamper's Avatar
superswamper
Remote Turn On
sure can.
Old Aug 2, 2003 | 12:47 AM
tripndrag's Avatar
tripndrag
Remote Turn On
You can also buy a relay and connect an ignition wire to the relay to trigger it , when you turn on your key, the ignition wire will get power and it will trip the relay and give power to your amp. Check the max amp draw of your amplifier and buy a relay that is slightly bigger, if your amp draws 25 amps then buy a 30 amp relay. You won't forget to turn it off if you do it this way.
Jera Lynn Hitlaw
General Automotive Discussion
Nov 27, 2015 11:12 PM
idaho potato
Jul 8, 2015 05:33 PM
65fsbk
May 18, 2014 11:39 AM
ezduzit23
Jan 24, 2014 08:31 AM
merlynr
Crossovers
Dec 22, 2009 10:09 AM
