Sponsored by: Real Truck
Replacement Ford Axle Housing?
Old Aug 10, 2015 | 01:32 PM
americanbulldog's Avatar
americanbulldog
Has anyone ordered a replacement front axle-housing from Ford?
The part number my dealer is showing for just the housing is #2C3Z3010-AA, and he shows the same part number for my 2001 SuperDuty and my buddy's 2004 (internet search appears to show the same part number all the way back to 1999). Obviously, Ford offered two different front axles for the SuperDuty during that period (the early Dana 50's and later Dana 60's). Is it safe to assume that a replacement housing for any of those years will now be the Dana 60/Dana 248 if they're all showing now as the same part number?
It only makes sense that it would be...but I'd love to verify that with anyone who's actually seen one. Thanks in advance!
Old Aug 10, 2015 | 01:51 PM
The John's Avatar
The John
why do you need to replace the housing?
I would assume that it would be cheaper to buy a donor then a new/unused housing but it all depends on why your replacing your current one...
Old Aug 10, 2015 | 02:01 PM
americanbulldog
Tried the junkyard donor route. Had an expensive bad experience, so now I'm trying to salvage things...no pun intended.
Parts person from the dealer actually just called back to advise he found the model split in the housings, so I think I'll be all set!
Thanks again!!!
Old Aug 10, 2015 | 03:56 PM
MisterCMK's Avatar
MisterCMK
Out of curiosity, how much are they asking for the axle housings?
Old Aug 10, 2015 | 05:50 PM
NYCruiser's Avatar
NYCruiser
If its a Dana 60 you may get a better deal contacting Dana directly.
Old Aug 10, 2015 | 06:51 PM
MisterCMK's Avatar
MisterCMK
You probably won't. It is a Ford part number, not a Dana number.
I doubt they would even sell you one
montego69
Mar 24, 2010 08:14 AM
Bacon2781
Aug 18, 2005 04:17 PM
newr
Apr 11, 2005 08:43 PM
mutt511
Offroad & 4x4
Apr 13, 2003 01:33 PM
